DenisSh
(Denis)
June 3, 2020, 4:36pm
1
Please help me with:
Invalid config for [automation]: [entity] is an invalid option for [automation]. Check: automation->trigger->0->entity. (See /config/configuration.yaml, line 165).
my automations.yaml
- alias: 'Home automation'
platform: state
entity: sensor.kitchen_wall_button
to: 'on'
condition:
condition: state
entity_id: switch.sw_one
state: 'off'
- service: switch.turn_on
message: 'Тик Так 10 сек'
- delay:
seconds: 10
- service: switch.turn_off
message: 'Выключаю'
the entity in the trigger block (from configuration.yaml):
kitchen_wall_button:
value_template: "{{states.sensor.esp.attributes.push_btn}}"
friendly_name: 'DSH wall button'
work well - I can see it state in Lovelace
DenisSh
(Denis)
June 3, 2020, 4:42pm
2
and I have also tried to put id:
- id: my_unique_id
platform: state
to: 'on'
condition:
condition: state
state: 'off'
- delay:
seconds: 10
message: 'Выключаю'
the result are same.
It seems to me that something wrong with: entity: sensor.kitchen_wall_button
but I can’t understand what’s wrong.
DenisSh
(Denis)
June 3, 2020, 5:07pm
5
tom_l:
entity_id
, not entity
what do you mean? could you explain?
Read your code carefully and look for entity
and replace with entity_id
DenisSh
(Denis)
June 3, 2020, 5:25pm
7
thank you! now that Error solved - I’m happy
By the way - after I have solved this problem another one comes with this code:
Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data['message']
What can you advise to me?
You cannot use a message with a switch service.
DenisSh
(Denis)
June 3, 2020, 5:30pm
9
thank you!
I have deleted all messages and it works
