I have been stuck with my problem for a good while now, for some X reason I just cannot get the SYMLINK’s working (I suppose?).
Here is my configuration for docker-compose.yaml:
HomeAssistant volumes
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- /opt/homeassistant/config:/config
- /etc/localtime:/etc/localtime:ro
- /opt/LetsEncrypt/appdata/config/etc/letsencrypt:/opt/LetsEncrypt/appdata/config/etc/letsencrypt
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
restart: unless-stopped
privileged: true
network_mode: host
Swag and it’s volumes
> swag:
image: linuxserver/letsencrypt
container_name: swag
cap_add:
- NET_ADMIN
environment:
- PUID=1000
- PGID=1000
- TZ=Europe/Helsinki
- URL=*mydomain*.duckdns.org
- SUBDOMAINS=wildcard
- VALIDATION=duckdns
- DNSPLUGIN=cloudflare #optional
- PROPAGATION= #optional
- DUCKDNSTOKEN=*my created token is here*
- EMAIL= #optional
- ONLY_SUBDOMAINS=false #optional
- EXTRA_DOMAINS= #optional
- STAGING=false #optional
volumes:
- /opt/LetsEncrypt/appdata/config:/config
ports:
- 443:443
#- 80:80 #optional
I did the tricks that were helping for others just fine:
cd homeassistant/config
ln -s -T /opt/LetsEncrypt/appdata/config/etc/letsencrypt/live/*MyDomainName*.duckdns.org /opt/homeassistant/config/ssl
That command creates the SSL folder under homeassistant/config/ssl, and I gave 777 access for the folder just to test and these are the permissions that it shows me:
HATT@HACon:/opt/homeassistant/config/ssl$ ls -l
total 24
lrwxrwxrwx 1 HATT HATT 48 heinä 27 00:31 cert.pem -> ../../archive/*MyDomainName*.duckdns.org/cert1.pem
lrwxrwxrwx 1 HATT HATT 49 heinä 27 00:31 chain.pem -> ../../archive/*MyDomainName*.duckdns.org/chain1.pem
lrwxrwxrwx 1 HATT HATT 53 heinä 27 00:31 fullchain.pem -> ../../archive/*MyDomainName*.duckdns.org/fullchain1.pem
-rwxrwxrwx 1 HATT HATT 9237 heinä 27 00:31 priv-fullchain-bundle.pem
lrwxrwxrwx 1 HATT HATT 51 heinä 27 00:31 privkey.pem -> ../../archive/*MyDomainName*.duckdns.org/privkey1.pem
-rwxrwxrwx 1 HATT HATT7125 heinä 27 00:31 privkey.pfx
-rwxrwxrwx 1 HATT HATT 692 heinä 27 00:31 README
So with all that, I put in the HomeAssistant’s configuration.yaml this:
http:
base_url: https://*MyDomainName*.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
and I can’t get anywhere, this is the full error:
not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 10).
What am I missing here? I felt like I was so close to figuring this out from others posts, but in my eyes I’ve done everything that they did - even with variations. Still no luck
