jacoscar
(Jacopo)
December 2, 2023, 12:20pm
1
All of a sudden my mqtt entities have stopped working; I haven’t changed any configuration for a long time
If I “check configuration” under Developer tools/YAML I get
Invalid config for [mqtt]: required key not provided @ data[‘mqtt’][‘light’][10][‘command_topic’]. Got None. (See /config/configuration.yaml, line 99
I haven’t changed anything in a long time and I haven’t updated anything recently; everything was working fine until last night
Troon
(Troon)
December 2, 2023, 12:28pm
2
It’s complaining about the eleventh light ([10]
). Please post code as correctly-formatted text not screenshots.
jacoscar
(Jacopo)
December 2, 2023, 1:17pm
3
Ok, so these first two entities are the 9th and 10th lights;
- name: "Bedroom2"
state_topic: "shellies/shelly1-BCDDC27742AD/relay/0"
command_topic: "shellies/shelly1-BCDDC27742AD/relay/0/command"
payload_on: "on"
payload_off: "off"
retain: false
- name: "Bedroom3"
state_topic: "shellies/shelly1-A4CF12F3E9D6/relay/0"
command_topic: "shellies/shelly1-A4CF12F3E9D6/relay/0/command"
payload_on: "on"
payload_off: "off"
retain: false
- name: "Prism hello"
state_topic: "prism/hello"
- name: "Prism stato"
state_topic: "prism/1/state"
value_template: >
{% set map = {
'1': 'nessun veicolo connesso',
'2': 'veicolo connesso, in attesa di ricaricare',
'3': 'veicolo in carica',
'4': 'carica in pausa'
{{ map[value] if value in map else 'error' }}
- name: "Prism corrente"
state_topic: "prism/1/amp"
unit_of_measurement: 'mA'
I already solved this by adding
between the 10th and 11th entity (which is not a light). What I don’t understand is why this hasn’t been a problem until now
WallyR
(Wally)
December 2, 2023, 1:20pm
4
It might have been a problem all a long, but the checks have not caught it.
The check code is being updated now and then, so the update could mean that it is suddenly caught.
