Invalid config for [script]: [bin_fairy_which_bins] is an invalid option for [script]
I’ve seen other questions with this title, but I can’t seem to find where I screwed up the syntax. Writing a simple script that would concatenate which bins are to be collected, and tts_say’ing the response to Google Assistant:
bin_fairy_which_bins:
  alias: "Which bins will be collected"
  icon: mdi:delete-empty
  mode: single
  sequence:
    - variables:
        message: >
          {%- set messageToSay = "The following bins will be collected: ") %}
          {%- if states('sensor.sua_bincollection_next_includes_recycling') == 'true' %}
            {%- set messageToSay = messageToSay + "Recycling, " %}
          {%- endif %}
          {%- if states('sensor.sua_bincollection_next_includes_garden_waste') == 'true' %}
            {%- set messageToSay = messageToSay + "Garden Waste, " %}
          {%- endif %}
          {%- if states('sensor.sua_bincollection_next_includes_general_refuse') == 'true' %}
            {%- set messageToSay = messageToSay + "General Refuse, " %}
          {%- endif %}
          {%- set messageToSay = messageToSay + "and Food waste." %}
          {{ messageToSay }}
    - alias: "TTS for speaker voice command"
      service: script.google_home_voice
        use_resume: true
          - alias: "Send TTS message"
            service: tts.google_cloud_say
              message: "{{ message }}"
        volume: 35
This file is saved as bin_fairy_which_bins.yaml in the path /scripts.
configuration.yaml then contains:
script: !include_dir_named scripts
When I load the scripts in the Developer Tools, this error shows up in the Log:
Invalid config for [script]: [bin_fairy_which_bins] is an invalid option for [script]. Check: script->bin_fairy_which_bins. (See /config/configuration.yaml, line 11).
script: !include_dir_merge_named scripts
Lol… always where you’re not looking. Thanks.
