I wrote a custom component in my Home Assistant 0.40 Branch, and the configuration of that component gives back a rather cryptic Error:
ERROR:homeassistant.config:Invalid config for [lablink_ha]: [homeassistant] is an invalid option for [lablink_ha]. Check: lablink_ha->homeassistant. (See ?, line ?). Please check the docs at https://home-assistant.io/components/lablink_ha/
ERROR:homeassistant.setup:Setup failed for lablink_ha: Invalid config.
My configuration.yaml:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 48.2333
lablink_ha:
and my code from homeassistant/components/lablink_ha/init.py:
import logging
import jpype
import lablink
import lablink.lablink_connection as llcon
import voluptuous as vol
from homeassistant.helpers import config_validation as cv
from homeassistant.const import (
EVENT_HOMEASSISTANT_START, EVENT_HOMEASSISTANT_STOP)
_LOGGER = logging.getLogger(__name__)
DOMAIN = "lablink_ha"
REQUIREMENTS = ["lablink==0.1.3"]
CONF_BROKER = "broker"
CONF_PORT = "port"
CONF_PROTOCOL = "protocol"
CONF_ENABLE_RE = "reconnect"
CONF_DOMAIN = "domain"
CONF_APP = "app"
CONF_GROUP = "group"
CONF_NAME = "name"
DEFAULT_BROKER = "localhost"
DEFAULT_PORT = 1883
DEFAULT_DOMAIN = ""
DEFAULT_APP = "HA"
DEFAULT_GROUP = "Group1"
DEFAULT_NAME = "HomeAssistant"
CONFIG_SCHEMA = vol.Schema({
DOMAIN: vol.Schema({
vol.Optional(CONF_DOMAIN, default=DEFAULT_DOMAIN): cv.string,
vol.Optional(CONF_APP, default=DEFAULT_APP): cv.string,
vol.Optional(CONF_GROUP, default=DEFAULT_GROUP): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_BROKER, default=DEFAULT_BROKER): cv.string,
vol.Optional(CONF_PORT, default=DEFAULT_PORT): cv.positive_int,
vol.Optional(CONF_PROTOCOL): cv.string,
vol.Optional(CONF_ENABLE_RE): cv.boolean,
}, extra=vol.ALLOW_EXTRA)})
lablink_con = None
def setup(hass, config):
"""Lablink setup"""
config = config.get(DOMAIN, {})
lablink.start_jvm()
_LOGGER.debug("JVM started")
global lablink_con
lablink_con = LablinkConnection(
platform_domain=config[CONF_DOMAIN],
platform_app=config[CONF_APP],
platform_group=config[CONF_GROUP],
platform_name=config[CONF_NAME],
connect_broker=config[CONF_BROKER],
connect_port=config[CONF_PORT])
def stop_lablink():
"""Stop the Lablink Service"""
lablink_con.shutdown_connection()
def start_lablink():
"""Start the Lablink Service"""
lablink_con.start_connection()
hass.bus.listen_once(EVENT_HOMEASSISTANT_STOP, stop_lablink)
hass.bus.listen_once(EVENT_HOMEASSISTANT_START, start_lablink)
return True
class LablinkConnection():
def __init__(self, platform_domain, platform_app, platform_group,
platform_name, connect_broker, connect_port,
connect_protocol=None, connect_enable_re=None):
self.platform_domain = platform_domain
self.platform_app = platform_app
self.platform_group = platform_group
self.platform_name = platform_name
self.connect_broker = connect_broker
self.connect_port = connect_port
self.connect_protocol = connect_protocol or "tcp"
self.connect_enable_re = connect_enable_re or True
BaseConfiguration = jpype.JClass(
"org.apache.commons.configuration.BaseConfiguration")
config = BaseConfiguration()
config.addProperty("lowLevelComm.brokerAddress", self.connect_broker)
config.addProperty("lowLevelComm.brokerPort", self.connect_port)
if not self.connect_enable_re:
config.addProperty("lowLevelComm.enableReconnection",
self.connect_enable_re)
if self.connect_protocol != "tcp":
config.addProperty("lowLevelComm.connectionProtocol",
self.connect_protocol)
self.ll_connection = llcon.LabLinkConnection(self.platform_domain,
self.platform_app,
self.platform_group,
self.platform_name,)
def start_connection(self):
lablink.start_jvm()
self.ll_connection.connect()
_LOGGER.debug("lablink_ha connection has been established")
def shutdown_connection(self):
self.ll_connection.disconnect()
self.ll_connection.shutdown()
_LOGGER.debug("lablink_ha connection has been shut down")
lablink.shutdown_jvm()
_LOGGER.debug("lablink_ha core has been shut down")
return False
I’m not quite sure what to make of this Error, as it keeps popping up no matter what i change.
Do I have to register my component with Home Assistant somehow?
I have tried several different configurations, like adding all the optional arguments and moving my component to the custom_components folder in the CONFIG directory, but i keep getting the same Error.
What does it mean that [homeassistant] is an invalid option for [lablink_ha]?
I would appreciate it if someone could show me in the right direction here ,
I’m really out of ideas!
thanks!
