Invalid config for [sensor]: expected a dictionary. Got
This is my first issue that I write on the forum so don’t be to harsh about my formating
I’ve run into a problem that I can’t figure it out. I didn’t change nothing in the configuration.yaml but whenever I try to check configuration for restart I get this error message
invalid config for [sensor]: expected a dictionary. Got {‘default_config’: {}, ‘frontend’: {‘themes’: {‘vintage’: {‘primary-font-family’: ‘Lucida Console’, ‘turmeric-color’: ‘#DEB853’, ‘light-turmeric-color’: ‘#E2D9A2’, ‘slate-color’: ‘#0A373A’, ‘light-slate-color’: ‘#789F8A’, ‘maroon-color’: ‘#862715’, ‘app-header-text-color’: ‘#fafcfb’, ‘primary-color’: ‘var(–slate-color)’, ‘light-primary-color’: ‘var(–light-turmeric-color)’, ‘dark-primary-color’: ‘var(–maroon-color)’, ‘primary-background-color’: ‘var(–light-turmeric-color)’, 'secondary-back… (See ?, line ?).
I’ve tried to remove the custom themes, but then the error moves to the automation.yaml and then to script.yaml
My configuration.yaml has this setup:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Enable Themes
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Include in HA customize file
homeassistant:
  customize: !include customize.yaml
  packages: !include_dir_named integrations
  auth_providers:
    - type: homeassistant
    - type: trusted_networks
      trusted_networks:
        - 192.168.x.x/24
        - 10.1.xx.x/24
      trusted_users:
        192.168.x.xx
  external_url: "https://xxxxxsfdas.ui.nabu.casa"
  allowlist_external_dirs:
    - "/config"
Did you recently create some template sensors? Then check this file(s).
