Hello all. I’ve searched around for a solution for my problem, but so far I don’t understand what exactly the issue is.
I use the utility integration to get daily power consumption data from the peak and off-peak power consumption data that I retrieve through the DSMR integration. Now I want to add those two values together in a sensor (at least, from what I read that’s the place to do it) so I know the total consumption.
So in my configuration.yaml file I’ve included a sensor.yaml file:
sensor: !include sensor.yaml
And then in sensor.yaml I’ve added the sensor config:
template:
- sensor:
- name: "Elektra dagelijks totaal"
unit_of_measurement: "kWh"
state: "{{ ((states('sensor.elektra_dagelijks_dal') | float | round(2)) + (states('sensor.elektra_dagelijks_normaal') | float | round(2))) }}"
When I validate the code with the template function in developer tools I get the correct output:
template:
- sensor:
state: "3.14"
But when I try to validate the config I get this error:
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None.
And don’t understand the platform message. What does it want me to add and where should I add it?
Thanks in advance!
