Invalid config for [sensor.statistics]: required key not provided @ data['state_characteristic']. Got None. (See ?, line ?)
since yesterday my Home Assistant Instance show me this error:
Invalid config for [sensor.statistics]: required key not provided @ data['state_characteristic']. Got None. (See ?, line ?).
Did anyone have an idea to solve this.
I’ve deletet all statistic entities with problems.
Have the same error…
See for the solution:
https://community.home-assistant.io/t/the-entity-id-option-is-deprecated-please-remove-it-from-your-configuration/227764
But it’s a complicated one…
I have:
# Overige statistieken in utility.yaml
  - platform: statistics
    name: Ford km stats
    entity_id: sensor.fordpass_odometer
    sampling_size: 20
But don’t know how to solve this.
I had the same error now after the latest OS update. (OS 9.4)
It seems that the statistics sensor now requires a state characteristic to be defined.
Check out the documentation for more options, Statistics
Here is an example of a statistics sensor with state_characteristic: mean added.
    entity_id: sensor.Power_Battery_SOC
    precision: 1
    sampling_size: 5
    max_age:
    minutes: 20
Adding state_characteristic: mean, solved this issue for me.
thanks, that work for me
