I’m trying to use an entity id based on input_select
state.
Here is my template_switch :
bedroom_ac_by_input:
friendly_name: AC By input
value_template: "{{ is_state('switch.bedroom_ac_25_cool_auto_fan', 'on') }}"
turn_on:
service: switch.turn_on
data_template:
entity_id: >
{% if is_state("input_select.bedroom_ac", "Cool - Auto fan") %}
{%-elif is_state("input_select.bedroom_ac", "Cool - Low fan") %}
switch.bedroom_ac_25_cool_low_fan
{%-elif is_state("input_select.bedroom_ac", "Heat - Auto fan") %}
switch.bedroom_ac_25_heat_auto_fan
{%-elif is_state("input_select.bedroom_ac", "Heat - Low fan" %}
switch.bedroom_ac_25_heat_low_fan
{%-else %}
none
{% endif %}
turn_off:
service: switch.turn_off
data_template:
entity_id: >
{% if is_state("input_select.bedroom_ac", "Cool - Auto fan'" %}
{%-elif is_state("input_select.bedroom_ac", "Heat - Low fan") %}
{%-else %}
none
{% endif %}
Here is the error :
2018-01-02 13:14:16 ERROR (MainThread) [homeassistant.config] Invalid config for [switch.template]: invalid template (TemplateSyntaxError: unexpected '}', expected ')') for dictionary value @ data['switches']['bedroom_ac_by_input']['turn_off'][0]['data_template']['entity_id']. Got None
invalid template (TemplateSyntaxError: unexpected '}', expected ')') for dictionary value @ data['switches']['bedroom_ac_by_input']['turn_on'][0]['data_template']['entity_id']. Got None.
(See ?, line ?). Please check the docs at https://home-assistant.io/components/switch.template/
I’ve compared all the characters (I hope) to the example at:
At I can’t see any difference.
