Logger: homeassistant.config
Source: config.py:978
First occurred: 13 juli 2023 kl. 18:26:00 (1 occurrences)
Last logged: 13 juli 2023 kl. 18:26:00
Invalid config for [template]: [name] is an invalid option for [template]. Check: template->name. (See /config/configuration.yaml, line 57)
# Loads default set of integrations. Do not remove.
default_config:
my:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
#sensor: !include sensor.yaml
- platform: nordpool
# Should the prices include vat? Default True
VAT: False
# What currency the api fetches the prices in
# this is only need if you want a sensor in a non local currency
currency: "SEK"
# Option to show prices in cents (or the equivalent in local currency)
price_in_cents: false
# Helper so you can set your "low" price
# low_price = hour_price < average * low_price_cutoff
low_price_cutoff: 0.95
# What power regions your are interested in.
# Possible values: "DK1", "DK2", "FI", "LT", "LV", "Oslo", "Kr.sand", "Bergen", "Molde", "Tr.heim", "Tromsø", "SE1", "SE2", "SE3","SE4", "SYS", "EE"
region: "SE3"
# How many decimals to use in the display of the price
precision: 3
# What the price should be displayed in default
# Possible values: MWh, kWh and Wh
# default: kWh
price_type: kWh
# This option allows the usage of a template to add a tariff.
# now() always refers start of the hour of that price.
# this way we can calculate the correct costs add that to graphs etc.
# The price result of the additional_costs template expects this additional cost to be in kWh and not cents as a float
# default {{0.0|float}}
additional_costs: "{{0.0|float}}"
template:
- sensor:
unit_of_measurement: kWh
state_class: total_increasing
device_class: energy
state: "{{ states('input_number.stromablesen') }}"
- sensor:
- name: sophamtning_days
state: >-
{{ min(((state_attr('calendar.sophamtning', 'start_time') | as_timestamp - today_at('00:00') | as_timestamp) / 86400) | int,2) }}
attributes:
days: >-
{{ ((state_attr('calendar.sophamtning', 'start_time') | as_timestamp - today_at('00:00') | as_timestamp) / 86400) | int }}
On line 57 it’s
template:
- sensor:
So something with that one, what am i doing wrong? Help out a beginner
