Hi All,
I’m trying to change my configuration.yaml ready for the MQTT changes in 2022.12.0.
I have removed my switch platform mqtt section and added:
mqtt:
switch:
- name: "Doorbell"
- command_topic: "cmnd/rf-bridge/Backlog"
- availability_topic: "tele/rf-bridge/LWT"
- payload_available: "Online"
- payload_not_available: "Offline"
- state_topic: "tele/rf-bridge/RESULT"
- value_template: '{{value_json.RfCode}}'
- payload_on: "RfSync 12220; RfLow 440; RfHigh 1210; RfCode #AA B1 04 0140 0B86 03B6 0F78 381A08282A0A0A082A0A0A08282A0A0828282828282A0828282828 55"
- payload_off: "RfSync 12220; RfLow 440; RfHigh 1210; RfCode #AA B1 04 0140 0B86 03B6 0F78 381A08282A0A0A082A0A0A08282A0A0828282828282A0828282828 55_off"
- state_on: "#47D655"
- state_off: "#47D655_off"
- optimistic: true
- retain: false
- qos: 2
Now I get an error when rebooting:
‘The system cannot restart because the configuration is not valid: Invalid config for [mqtt]: required key not provided @ data[‘mqtt’][‘switch’][0][‘command_topic’]. Got None. (See /config/configuration.yaml’
It points to the line where I added mqtt:
Any clues or advice please?
Full config file here: # Configure a default setup of Home Assistant (frontend, api, etc)default_co - Pastebin.com
