Invalid Config History, Log and default_config
I have noticed that I keep getting that notification:
The following integrations and platforms could not be set up:
* [logbook](https://www.home-assistant.io/integrations/logbook)
* [history](https://www.home-assistant.io/integrations/history)
* [default_config](https://www.home-assistant.io/integrations/default_config)
Please check your config and [logs](https://ha.ppmt.org/config/logs).
I think it appeared recently either wiht 2021.05 or 2021.05 but not so sure.
In the logs I can see this:
Error doing job: Exception in callback Recorder.async_connection_failed()
19:16:13 – (ERROR) components/recorder/__init__.py
Error during connection setup to mysql://hass:redacted@core-mariadb/homeassistant?charset=utf8mb4: (MySQLdb._exceptions.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)") (Background on this error at: http://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
19:16:10 – (ERROR) recorder - message first occurred at 19:10:28 and shows up 10 times
I thought the mariadb addon didn’t start properly so I restarted it and then restarted HA but it stayed the same. I even uninstalled it and reinstalled it but it didn’t help.
The addon itself says it started properly.
I read the latest release note but could not find anything that is related.
Do you have any advice on how to troubleshoot my issue?
What does your configuration for the recorder integration look like?
This is mine and it is working:
recorder: mysql://hass:my_password_redacted@core-mariadb/homeassistant?charset=utf8
Corresponding mariadb addon configuration:
databases:
  - homeassistant
logins:
  - username: hass
    password: my_password_redacted
rights:
  - username: hass
    database: homeassistant
Edit: actually I can see it in the error message. The only difference is that you are using ?charset=utf8mb4 where as I am using ?charset=utf8
Also I can see your database password in that error message. You might want to change it.
Hello @tom_l and thanks for your input.
I have changed the config and it still is the same. It was actually as yours before but I tried that setting after reading the doc and it mentioned that setting
databases:
  - homeassistant
logins:
  - username: hass
    password: redacted
rights:
  - username: hass
recorder:
  #db_url: !secret mariadb_url
  db_url: mysql://hass:redacted@core-mariadb/homeassistant?charset=utf8
  commit_interval: 30
  purge_keep_days: 4
it says that core-mariadb doesn’t exist but it always worked like that before
Error during connection setup to mysql://hass:redacted@core-mariadb/homeassistant?charset=utf8: (MySQLdb._exceptions.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)") (Background on this error at: http://sqlalche.me/e/14/e3q8) (retrying in 3 seconds)
sqlalchemy.exc.OperationalError: (MySQLdb._exceptions.OperationalError) (2005, "Unknown MySQL server host 'core-mariadb' (-3)")
I did the update to 2021.5.4 and the problem is fixed.
Not sure what happened but all sorted for now
