nuki47
(Nuki47)
1
I always get this notification, but I don’t have a configuration for ICS in my configuration.yaml :
The following integrations and platforms could not be set up:
Please check your config and [logs]
LOG:
Logger: homeassistant.setup
Source: setup.py:138
First occurred: 13:12:25 (1 occurrences)
Last logged: 13:12:25
Setup failed for ics: Integration not found.
Are you using any custom components for calendar? Are you sure you don’t have ics:
somewhere in your config files?
Did you search all your files for ics:
nuki47
(Nuki47)
5
I tried via SSH (but works this for a docker also?)
find -iname ics
and also via Explorer, but no resultut
Do you have samba access to your files? If so open the config folder with VSCode or any other proper IDE and search for it.
This (searching with windoof explorer) will look only for filenames not for text inside the files.
nuki47
(Nuki47)
9
ok, you are right, with VSCode I found something in .storage/core.config_entries
