I just got HA Green. I set it up based on the insturctions via my browser. I am getting the following notifications on start up each time:
Invalid config
The following integrations and platforms could not be set up:
cloud (Show logs)
zeroconf (Show logs)
conversation (Show logs)
assist_pipeline (Show logs)
mobile_app (Show logs)
default_config (Show logs)
Please check your config and logs.
from .connection import SamsungTVWSConnection
File "/usr/local/lib/python3.13/site-packages/samsungtvws/connection.py", line 126, in <module>
class SamsungTVWSConnection(SamsungTVWSBaseConnection):
...<133 lines>...
return self.connection is not None and self.connection.connected
File "/usr/local/lib/python3.13/site-packages/samsungtvws/connection.py", line 127, in SamsungTVWSConnection
connection: Optional[websocket.WebSocket]
AttributeError: module 'websocket' has no attribute 'WebSocket'
2024-12-31 20:29:07.191 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module with args ('homeassistant.components.samsungtv.config_flow',) in /usr/src/homeassistant/homeassistant/loader.py, line 1303: return importlib.import_module(f"{self.pkg_path}.{platform_name}") inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 708, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 679, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2027, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 112, in sem_task
return await task
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1315, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1340, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1536, in async_create_flow
handler = await _async_get_flow_handler(
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3333, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3312, in _load_integration
await integration.async_get_platform("config_flow")
File "/usr/src/homeassistant/homeassistant/loader.py", line 1107, in async_get_platform
platforms = await self.async_get_platforms((platform_name,))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1172, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File "/usr/src/homeassistant/homeassistant/loader.py", line 1097, in _load_platforms
platform_name: self._load_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1271, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1303, in _import_platform
2024-12-31 20:29:07.252 ERROR (MainThread) [homeassistant.loader] Unexpected exception importing platform homeassistant.components.samsungtv.config_flow
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 200, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1310, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1022, in exec_module
File "/usr/src/homeassistant/homeassistant/components/samsungtv/__init__.py", line 29, in <module>
from .bridge import (
...<4 lines>...
File "/usr/src/homeassistant/homeassistant/components/samsungtv/bridge.py", line 15, in <module>
from samsungtvws.async_remote import SamsungTVWSAsyncRemote
File "/usr/local/lib/python3.13/site-packages/samsungtvws/__init__.py", line 9, in <module>
from .remote import SamsungTVWS
File "/usr/local/lib/python3.13/site-packages/samsungtvws/remote.py", line 16, in <module>
from . import art, connection, helper, rest, shortcuts
File "/usr/local/lib/python3.13/site-packages/samsungtvws/art.py", line 22, in <module>
...<133 lines>...
2024-12-31 20:29:07.278 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration samsungtv: Exception importing homeassistant.components.samsungtv.config_flow
2024-12-31 20:29:07.281 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved (None)
...<4 lines>...
...<133 lines>...
File "/usr/src/homeassistant/homeassistant/loader.py", line 1184, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1291, in _load_platform
raise ImportError(
f"Exception importing {self.pkg_path}.{platform_name}"
) from err
ImportError: Exception importing homeassistant.components.samsungtv.config_flow
File "/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py", line 137, in _async_start
await gather_with_limited_concurrency(FLOW_INIT_LIMIT, *init_coros)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 114, in gather_with_limited_concurrency
return await gather(
...<2 lines>...
return await task
self.hass, handler_key, self._hass_config
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3319, in _load_integration
raise data_entry_flow.UnknownHandler from err
homeassistant.data_entry_flow.UnknownHandler
2024-12-31 20:29:07.560 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration sonos: cannot import name 'parse' from 'xmltodict' (/usr/local/lib/python3.13/site-packages/xmltodict.py)
2024-12-31 20:29:07.563 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration sonos: cannot import name 'parse' from 'xmltodict' (/usr/local/lib/python3.13/site-packages/xmltodict.py)
2024-12-31 20:29:07.564 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration sonos: cannot import name 'parse' from 'xmltodict' (/usr/local/lib/python3.13/site-packages/xmltodict.py)
2024-12-31 20:29:07.566 ERROR (MainThread) [homeassistant.config_entries] Error occurred loading flow for integration sonos: cannot import name 'parse' from 'xmltodict' (/usr/local/lib/python3.13/site-packages/xmltodict.py)
I can share more logs or whatever else would be helpful.
