2024-11-10 06:22:05.846 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.00 seconds
2024-11-10 06:22:05.854 INFO (MainThread) [homeassistant.setup] Setting up frontend
2024-11-10 06:22:05.864 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.01 seconds
2024-11-10 06:22:05.865 INFO (MainThread) [homeassistant.bootstrap] Setting up recorder: {'recorder'}
2024-11-10 06:22:05.869 INFO (MainThread) [homeassistant.components.http] Now listening on port 8223
2024-11-10 06:22:05.870 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.01 seconds
2024-11-10 06:22:05.877 INFO (MainThread) [homeassistant.setup] Setting up recorder
2024-11-10 06:22:05.884 DEBUG (Recorder) [homeassistant.components.recorder.util] The last run ended at: 2024-11-10 05:20:56.598429+00:00 (now: 2024-11-10 05:22:05.884444+00:00)
2024-11-10 06:22:05.884 DEBUG (Recorder) [homeassistant.components.recorder.util] The system was restarted cleanly and passed the basic sanity check
2024-11-10 06:22:05.888 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Created new connection <sqlite3.Connection object at 0x7f5055e4bf10>
2024-11-10 06:22:05.893 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.894 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.894 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:05.894 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.895 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.895 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> reset, transaction already reset
2024-11-10 06:22:05.895 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.897 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.898 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> reset, transaction already reset
2024-11-10 06:22:05.898 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.909 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.909 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:05.910 DEBUG (Recorder) [homeassistant.components.recorder.core] Connected to recorder database
2024-11-10 06:22:05.911 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.918 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.919 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:05.919 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.921 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.921 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:05.923 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:05.927 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:05.927 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:05.928 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:06.118 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:06.118 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:06.120 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:06.130 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> being returned to pool
2024-11-10 06:22:06.130 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> rollback-on-return
2024-11-10 06:22:06.131 DEBUG (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Connection <sqlite3.Connection object at 0x7f5055e4bf10> checked out from pool
2024-11-10 06:22:06.132 DEBUG (Recorder) [homeassistant.components.recorder.migration] Activating event_types manager as all data is migrated
2024-11-10 06:22:06.132 DEBUG (Recorder) [homeassistant.components.recorder.migration] Activating states_meta manager as all data is migrated
2024-11-10 06:22:12.046 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [139983008564272] Received unknown command: supervisor/api
2024-11-10 06:22:12.047 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [139983008564272] Received unknown command: supervisor/api
2024-11-10 06:22:12.136 WARNING (MainThread) [asyncio] socket.send() raised exception.
2024-11-10 06:22:12.138 WARNING (MainThread) [asyncio] socket.send() raised exception.
2024-11-10 06:22:12.266 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [139983008564992] Received unknown command: sensor/numeric_device_classes
2024-11-10 06:22:15.879 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2024-11-10 06:23:05.503 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 766.408331047}
2024-11-10 06:24:05.612 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 766.408331047}
2024-11-10 06:25:05.727 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 766.408331047}
2024-11-10 06:26:05.828 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 766.408331047}
2024-11-10 06:27:05.878 DEBUG (MainThread) [homeassistant.components.recorder.core] Recorder queue size is: 9
2024-11-10 06:27:05.879 ERROR (MainThread) [homeassistant.setup] Setup of 'recorder' is taking longer than 300 seconds. Startup will proceed without waiting any longer
2024-11-10 06:27:05.879 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 300.00 seconds
2024-11-10 06:27:05.880 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'cloud', 'repairs', 'network', 'zeroconf', 'websocket_api', 'auth', 'dhcp', 'hassio', 'http', 'webhook', 'bluetooth', 'usb', 'ssdp', 'api'}
2024-11-10 06:27:05.881 INFO (MainThread) [homeassistant.setup] Setting up webhook
2024-11-10 06:27:05.882 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.00 seconds
2024-11-10 06:27:05.883 INFO (MainThread) [homeassistant.setup] Setting up network
2024-11-10 06:27:05.903 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.02 seconds
2024-11-10 06:27:05.904 INFO (MainThread) [homeassistant.setup] Setting up hassio
2024-11-10 06:27:05.937 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('hassio', None): 1066.435614386}
2024-11-10 06:27:07.739 INFO (MainThread) [homeassistant.setup] Setting up cloud
2024-11-10 06:27:07.744 INFO (MainThread) [homeassistant.setup] Setting up ffmpeg
2024-11-10 06:27:07.744 INFO (MainThread) [homeassistant.setup] Setup of domain ffmpeg took 0.00 seconds
2024-11-10 06:27:07.745 INFO (MainThread) [homeassistant.setup] Setting up tts
2024-11-10 06:27:07.746 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.01 seconds
2024-11-10 06:27:07.760 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.01 seconds
2024-11-10 06:27:07.823 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 1.92 seconds
2024-11-10 06:27:07.897 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2024-11-10 06:27:07.898 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.00 seconds
2024-11-10 06:27:07.898 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up hassio.binary_sensor
2024-11-10 06:27:07.901 INFO (MainThread) [homeassistant.setup] Setting up update
2024-11-10 06:27:07.902 INFO (MainThread) [homeassistant.setup] Setup of domain update took 0.00 seconds
2024-11-10 06:27:07.903 INFO (MainThread) [homeassistant.components.update] Setting up hassio.update
2024-11-10 06:27:07.921 INFO (MainThread) [homeassistant.setup] Setting up usb
2024-11-10 06:27:07.921 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.00 seconds
2024-11-10 06:27:08.103 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2024-11-10 06:27:08.115 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2024-11-10 06:27:08.116 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.01 seconds
2024-11-10 06:27:17.607 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2024-11-10 06:27:17.608 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.00 seconds
2024-11-10 06:27:18.231 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2024-11-10 06:27:18.240 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.01 seconds
2024-11-10 06:27:18.403 INFO (MainThread) [homeassistant.setup] Setting up sensor
2024-11-10 06:27:18.405 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2024-11-10 06:27:18.405 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.00 seconds
2024-11-10 06:27:18.406 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.00 seconds
2024-11-10 06:27:18.406 INFO (MainThread) [homeassistant.components.sensor] Setting up hassio.sensor
2024-11-10 06:27:21.375 INFO (MainThread) [homeassistant.setup] Setting up bluetooth
2024-11-10 06:27:22.016 INFO (MainThread) [homeassistant.setup] Setup of domain bluetooth took 0.64 seconds
2024-11-10 06:27:22.017 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'application_credentials', 'system_health', 'dnsip', 'mobile_app', 'balance_neto', 'radio_browser', 'edata', 'analytics', 'ffmpeg', 'pvpc_hourly_pricing', 'battery_notes', 'hacs', 'energy', 'google_translate', 'default_config', 'input_button', 'automation', 'input_number', 'persistent_notification', 'hardware', 'openweathermap', 'device_automation', 'sems', 'cast', 'diagnostics', 'panel_custom', 'ping', 'utility_meter', 'shell_command', 'config', 'command_line', 'shopping_list', 'xiaomi_miio', 'camera', 'go2rtc', 'input_boolean', 'smlight', 'xiaomi_miot', 'conversation', 'notify', 'image_upload', 'counter', 'flux_led', 'sun', 'assist_pipeline', 'homekit', 'file_upload', 'input_datetime', 'met', 'mqtt', 'zha', 'xiaomi_aqara', 'tuya', 'media_source', 'tag', 'wake_word', 'template', 'telegram_bot', 'script', 'speedtestdotnet', 'stt', 'person', 'schedule', 'zone', 'input_text', 'search', 'blueprint', 'tts', 'esphome', 'sensor', 'tasmota', 'trace', 'lovelace', 'forecast_solar', 'scene', 'fully_kiosk', 'intent', 'bluetooth_adapters', 'fastdotcom', 'tuya_climate_mult_edit', 'androidtv_remote', 'workday', 'stream', 'input_select', 'midea_ac_lan', 'logbook', 'history', 'xiaomi_ble', 'backup', 'alarmo', 'timer', 'dlna_dms', 'sonoff', 'onboarding', 'my', 'netatmo', 'co2signal', 'bodymiscale', 'tarifa_20td', 'homeassistant_alerts'}
2024-11-10 06:27:22.019 INFO (MainThread) [homeassistant.setup] Setting up wake_word
2024-11-10 06:27:22.019 INFO (MainThread) [homeassistant.setup] Setup of domain wake_word took 0.00 seconds
2024-11-10 06:27:22.019 INFO (MainThread) [homeassistant.setup] Setting up stt
2024-11-10 06:27:22.021 INFO (MainThread) [homeassistant.setup] Setup of domain stt took 0.00 seconds
2024-11-10 06:27:22.021 INFO (MainThread) [homeassistant.setup] Setting up scene
2024-11-10 06:27:22.024 INFO (MainThread) [homeassistant.components.scene] Setting up homeassistant.scene
2024-11-10 06:27:22.026 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.00 seconds
2024-11-10 06:27:22.027 INFO (MainThread) [homeassistant.setup] Setting up camera
2024-11-10 06:27:22.031 INFO (MainThread) [homeassistant.setup] Setup of domain camera took 0.00 seconds
2024-11-10 06:27:22.033 INFO (MainThread) [homeassistant.setup] Setting up system_health
2024-11-10 06:27:22.035 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.00 seconds
2024-11-10 06:27:22.037 INFO (MainThread) [homeassistant.setup] Setting up input_button
2024-11-10 06:27:22.039 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 0.00 seconds
2024-11-10 06:27:22.040 INFO (MainThread) [homeassistant.setup] Setting up trace
2024-11-10 06:27:22.040 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.00 seconds
2024-11-10 06:27:22.042 INFO (MainThread) [homeassistant.setup] Setting up panel_custom
2024-11-10 06:27:22.042 INFO (MainThread) [homeassistant.setup] Setup of domain panel_custom took 0.00 seconds
2024-11-10 06:27:22.043 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2024-11-10 06:27:22.045 INFO (MainThread) [homeassistant.setup] Setting up media_source
2024-11-10 06:27:22.047 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.00 seconds
2024-11-10 06:27:24.589 INFO (MainThread) [homeassistant.setup] Setting up template
2024-11-10 06:27:24.615 INFO (MainThread) [homeassistant.setup] Setup of domain template took 0.03 seconds
2024-11-10 06:27:24.645 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.670 INFO (MainThread) [homeassistant.setup] Setting up zone
2024-11-10 06:27:24.673 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.00 seconds
2024-11-10 06:27:24.676 INFO (MainThread) [homeassistant.setup] Setting up stream
2024-11-10 06:27:24.677 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'logbook'. Setup failed for dependencies: ['recorder']
2024-11-10 06:27:24.677 ERROR (MainThread) [homeassistant.setup] Setup failed for 'logbook': Could not setup dependencies: recorder
2024-11-10 06:27:24.680 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'edata'. Setup failed for dependencies: ['recorder']
2024-11-10 06:27:24.680 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration 'edata': Could not setup dependencies: recorder
2024-11-10 06:27:24.682 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'history'. Setup failed for dependencies: ['recorder']
2024-11-10 06:27:24.682 ERROR (MainThread) [homeassistant.setup] Setup failed for 'history': Could not setup dependencies: recorder
2024-11-10 06:27:24.683 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'energy'. Setup failed for dependencies: ['history', 'recorder']
2024-11-10 06:27:24.683 ERROR (MainThread) [homeassistant.setup] Setup failed for 'energy': Could not setup dependencies: history, recorder
2024-11-10 06:27:24.684 INFO (MainThread) [homeassistant.setup] Setting up input_number
2024-11-10 06:27:24.686 INFO (MainThread) [homeassistant.setup] Setting up input_select
2024-11-10 06:27:24.689 INFO (MainThread) [homeassistant.setup] Setting up timer
2024-11-10 06:27:24.693 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.00 seconds
2024-11-10 06:27:24.697 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.699 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.700 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.701 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.702 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.703 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.706 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.707 INFO (MainThread) [homeassistant.components.sensor] Setting up template.sensor
2024-11-10 06:27:24.751 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 2.71 seconds
2024-11-10 06:27:24.761 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.08 seconds
