It didn’t let me because of the file limit, I cut the file…
2024-11-10 05:29:34.442 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration xiaomi_miot which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.444 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sems which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.445 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.446 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tarifa_20td which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.447 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tuya_climate_mult_edit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.448 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bodymiscale which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.448 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration battery_notes which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.449 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration midea_ac_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.450 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration alarmo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.451 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.452 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.453 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration balance_neto which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:34.454 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration edata which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-11-10 05:29:46.581 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2024-11-10 05:30:36.190 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 950.371556013}
2024-11-10 05:31:36.300 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 950.371556013}
2024-11-10 05:32:36.427 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 950.371556013}
2024-11-10 05:33:36.530 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('recorder', None): 950.371556013}
2024-11-10 05:34:36.581 ERROR (MainThread) [homeassistant.setup] Setup of 'recorder' is taking longer than 300 seconds. Startup will proceed without waiting any longer
2024-11-10 05:34:36.633 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('hassio', None): 1250.376990087}
2024-11-10 05:34:52.777 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'edata'. Setup failed for dependencies: ['recorder']
2024-11-10 05:34:52.778 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration 'edata': Could not setup dependencies: recorder
2024-11-10 05:34:52.799 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'logbook'. Setup failed for dependencies: ['recorder']
2024-11-10 05:34:52.799 ERROR (MainThread) [homeassistant.setup] Setup failed for 'logbook': Could not setup dependencies: recorder
2024-11-10 05:34:52.802 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'history'. Setup failed for dependencies: ['recorder']
2024-11-10 05:34:52.802 ERROR (MainThread) [homeassistant.setup] Setup failed for 'history': Could not setup dependencies: recorder
2024-11-10 05:34:52.802 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'energy'. Setup failed for dependencies: ['history', 'recorder']
2024-11-10 05:34:52.802 ERROR (MainThread) [homeassistant.setup] Setup failed for 'energy': Could not setup dependencies: history, recorder
2024-11-10 05:35:18.697 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya_climate_mult_edit integration could not authenticate: Authentication failed. Please re-authenticate
2024-11-10 05:35:25.867 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya integration could not authenticate: Authentication failed. Please re-authenticate
2024-11-10 05:35:25.923 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya integration could not authenticate: Authentication failed. Please re-authenticate
2024-11-10 05:35:26.406 WARNING (ImportExecutor_0) [homeassistant.const] TIME_DAYS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTime.DAYS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.415 WARNING (ImportExecutor_0) [homeassistant.const] TIME_HOURS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTime.HOURS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.430 WARNING (ImportExecutor_0) [homeassistant.const] TIME_MINUTES was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTime.MINUTES instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.443 WARNING (ImportExecutor_0) [homeassistant.const] TIME_SECONDS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTime.SECONDS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.455 WARNING (ImportExecutor_0) [homeassistant.const] TEMP_CELSIUS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.464 WARNING (ImportExecutor_0) [homeassistant.const] POWER_WATT was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfPower.WATT instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.474 WARNING (ImportExecutor_0) [homeassistant.const] VOLUME_LITERS was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfVolume.LITERS instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:26.488 WARNING (ImportExecutor_0) [homeassistant.const] ENERGY_KILO_WATT_HOUR was used from midea_ac_lan, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfEnergy.KILO_WATT_HOUR instead, please report it to the author of the 'midea_ac_lan' custom integration
2024-11-10 05:35:29.269 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to import_module with args ('.ac.device', 'custom_components.midea_ac_lan.midea.devices') inside the event loop by custom integration 'midea_ac_lan' at custom_components/midea_ac_lan/midea/devices/__init__.py, line 23: module = import_module(device_path, __package__) (offender: /config/custom_components/midea_ac_lan/midea/devices/__init__.py, line 23: module = import_module(device_path, __package__)), please create a bug report at https://github.com/georgezhao2010/midea_ac_lan/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 223, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 209, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 189, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 674, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 641, in run_forever
self._run_once()
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1990, in _run_once
handle._run()
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 165, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 461, in _async_setup_component
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/setup.py", line 463, in <genexpr>
create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 783, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 546, in async_setup
await self.__async_setup_with_context(hass, integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 635, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/midea_ac_lan/__init__.py", line 148, in async_setup_entry
device = device_selector(
File "/config/custom_components/midea_ac_lan/midea/devices/__init__.py", line 23, in device_selector
2024-11-10 05:35:29.291 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'midea_ac_lan' calls async_forward_entry_setup for integration, midea_ac_lan with title: Aire de la habitación grande and entry_id: 7004219e313a9cbf9a9e6da8d01d55b5, which is deprecated and will stop working in Home Assistant 2025.6, await async_forward_entry_setups instead at custom_components/midea_ac_lan/__init__.py, line 171: hass.async_create_task(hass.config_entries.async_forward_entry_setup(, please create a bug report at https://github.com/georgezhao2010/midea_ac_lan/issues
2024-11-10 05:35:30.015 WARNING (MainThread) [homeassistant.setup] Setup of telegram_bot is taking over 10 seconds.
2024-11-10 05:35:33.781 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of 'default_config'. Setup failed for dependencies: ['energy', 'history', 'logbook']
2024-11-10 05:35:33.781 ERROR (MainThread) [homeassistant.setup] Setup failed for 'default_config': Could not setup dependencies: energy, history, logbook
2024-11-10 05:35:35.358 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire de la habitación grande and entry_id: 7004219e313a9cbf9a9e6da8d01d55b5, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
Stack (most recent call last):
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2318, in async_forward_entry_setup
_report_non_awaited_platform_forwards(entry, "async_forward_entry_setup")
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1194, in _report_non_awaited_platform_forwards
report(
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 156, in report
_LOGGER.warning(msg, stack_info=True)
2024-11-10 05:35:35.360 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire del salon and entry_id: 103a3fc82303710d527d518f7286aabd, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-11-10 05:35:35.368 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire de la habitación pequeña and entry_id: 773abc23d1475a31a1f0c0ee84c8b6d6, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-11-10 05:35:35.377 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire de la habitación grande and entry_id: 7004219e313a9cbf9a9e6da8d01d55b5, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-11-10 05:35:35.379 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire del salon and entry_id: 103a3fc82303710d527d518f7286aabd, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
2024-11-10 05:35:35.382 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls async_forward_entry_setup for integration midea_ac_lan with title: Aire de la habitación pequeña and entry_id: 773abc23d1475a31a1f0c0ee84c8b6d6, during setup without awaiting async_forward_entry_setup, which can cause the setup lock to be released before the setup is done. This will stop working in Home Assistant 2025.1. Please report this issue.
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
report(
