since I added a counter as helper, I get an error:
Invalid config
The following integrations and platforms could not be set up:
Please check your config and logs.
Logger: homeassistant.setup
Source: setup.py:182
First occurred: 12:33:28 (1 occurrences)
Last logged: 12:33:28Unable to set up dependencies of default_config. Setup failed for dependencies: counter
Source: setup.py:184
Last logged: 12:33:28Setup failed for default_config: (DependencyError(…), ‘Could not setup dependencies: counter’)
I also cant add a new counter.
There is an error like: "The counter-integration is not loaded. Please add to configuration as “default_config:” oder “counter”.
My configuration.yaml has default_config:
How can I fix this?
Regards
New-Bee
