Not sure what happened, but I am getting an invalid config error. The only things I changed were a quick automation to the automations.yaml, which I deleted to be sure it wasn’t the issue and I upgraded my z-wave JS and file editor add-ons. The configuration check is giving me this error…
Error loading /config/configuration.yaml: mapping values are not allowed here
in “/config/customize.yaml”, line 1, column 49
However, Iine is simply defauly_config: in my configuration file.
Here is my configuration.yaml…
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
#http:
#History Storage
recorder:
purge_keep_days: 7
# Panel Frames - Additional Panels for Home Assistant
panel_iframe:
rachio:
title: Rachio
url: "https://app.rach.io"
icon: mdi:water-pump
#router:
#title: UniFi
#url: "https://unifi.ui.com/"
#icon: mdi:lan
# Text to speech
tts:
- platform: google_translate
# Google Calendar
google:
client_id: xxxxxxx
client_secret: xxxxxxx
# Nest
nest:
client_id: xxxxxxx
# Bloomsky
bloomsky:
api_key: xxxxxxxx
camera:
- platform: bloomsky
# Harmony Hubs
#remote:
# - platform: harmony
# name: BSMT Harmony Hub
# host: 192.168.1.164
# name: KIT Harmony Hub
# host: 192.168.1.56
# name: LR Harmony Hub
# host: 192.168.1.74
# name: MB Harmony Hub
# host: 192.168.1.32
homeassistant:
customize: !include customize.yaml
cloud: !include_dir_merge_list cloud.yaml
group: !include_dir_merge_list groups.yaml
history: !include history.yaml
light: !include_dir_merge_list lights
media_player: !include media_players.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include_dir_merge_list sensors
switch: !include_dir_merge_list switches
brg468
(Brian)
April 26, 2021, 2:56pm
3
Sounds like it could be in your customize.yaml
file.
Also check the indentation on the line in configuration that has
Troon
(Troon)
April 26, 2021, 3:00pm
5
And the “mapping values” error usually means you have a colon in a “value”.
Watch your indenting: you have a few single-space indents in that configuration.yaml
(rachio
, bloomsky
, customize
(which should be left-aligned)).
nickrout
(Nick Rout)
April 27, 2021, 4:32am
6
Surely the message tells you exactly where the error is.
Bingo, the error was in the customize.yaml file. Which is odd, as I never touched the file…fixed now though! Thanks for the help.
nickrout
(Nick Rout)
April 27, 2021, 7:48pm
8
As you knew from the error message.
Yeah, I don’t know what I was thinking. I never touched the customization file so I was assuming it was the config for some reason. My fault.
