Invalid conversion from 'esphome::homeassistant::HomeassistantSensor*' to 'uint8_t
Hi folks!
I’m trying to pass an input number to a lambda function but I got this error:
invalid conversion from
esphome::homeassistant::HomeassistantSensor*' to 'uint8_t {aka unsigned char}' [-fpermissive]
         it.intensity(mynumber);
My code is the following:
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: !secret ssid
  password: !secret password
  ap:
    ssid: "Max7219 Test Fallback Hotspot"
    password: "1ObNXsEs5d8I"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      icon: mdi:wifi
    ssid:
      name: ESP Connected SSID
      icon: mdi:wifi
    bssid:
      name: ESP Connected BSSID
      icon: mdi:wifi
    mac_address:
      name: ESP Mac Wifi Address
      icon: mdi:chip
  - platform: homeassistant
    entity_id: input_text.max7219
    internal: true
    name: "Today Weather Icon"
    entity_id: weather.home
    internal: true
  - platform: wifi_signal
    icon: mdi:wifi
    update_interval: 60s
    entity_id: input_number.max7219_intensity
    internal: true
font:
  - file: "thintel.ttf"
spi:
  clk_pin: D5
  mosi_pin: D7
display:
  - platform: max7219digit
    cs_pin: D6
    num_chips: 4
    intensity: 1
    rotate_chip: 180
    reverse_enable: true
    lambda: |-
        it.scroll(true, 0, 100, 1000, 1000);
        it.print(it.get_width()/2, 11, id(digit_font), TextAlign::BOTTOM_CENTER, id(mytext).state.c_str());
Where I’m wrong?
Try:
it.intensity(id(mynumber).state);
yes, it is! many thanks!
