I’ve been having the same issue (including “shows up 10 times”). It started a couple/few releases back (I’m currently running 2022.10). I for the life of me can’t find root cause either. Please report back if you find a solution and I will do the same.
Do you also receive 10 occurrences? Have you tried reloading the Netatmo integration and/or the browser_mod integrations to see if that generate a fresh log entry?
my reloading netatmo give a whole other message btw:
Logger: homeassistant.config_entries
Source: components/netatmo/__init__.py:274
First occurred: 2:30:11 PM (1 occurrences)
Last logged: 2:30:11 PM
Error unloading entry Configuration.yaml for netatmo
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 498, in async_unload
result = await component.async_unload_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/netatmo/__init__.py", line 274, in async_unload_entry
await data[entry.entry_id][AUTH].async_dropwebhook()
File "/usr/local/lib/python3.10/site-packages/pyatmo/auth.py", line 431, in async_dropwebhook
resp = await self.async_post_api_request(
File "/usr/local/lib/python3.10/site-packages/pyatmo/auth.py", line 351, in async_post_api_request
return await self.async_post_request(
File "/usr/local/lib/python3.10/site-packages/pyatmo/auth.py", line 389, in async_post_request
raise ApiError(
pyatmo.exceptions.ApiError: 406 - Not Acceptable - Nothing to drop (7) when accessing 'https://api.netatmo.com/api/dropwebhook'
which is weird:
1 i have no longer the netatmo in confguration.yaml
2 i have not webhooks configured (only have weather station devices)
I’m still getting this error and I’m running the latest HAC 2022.11.1
Logger: homeassistant.helpers.entity_platform
Source: helpers/entity_platform.py:567
First occurred: 8:05:22 AM (10 occurrences)
Last logged: 8:05:22 AM
Ignoring invalid device configuration_url ''
Also having this issue with 1 of my 2 Precence camera’s. It appeared after one WIFI accespoint went down today because of a powerfailure. Everything is up and running again, except rebooting Home Assistant wont’ get my camera back a live in the dashboard. Have seen it before, tomorrow probably it wil work again all suddenly.
It’s like Netatmo has enough of Home Assistant trying to reach my Presence while the wifi is down and they blocked me for a day. All this is my gut feeling and pure speculation because I think that is what I see.
First occurred: 12:39:10 (10 occurrences)
Last logged: 12:39:10
This sounds more like the camera did not properly propagate/update it’s IP address to the Netatmo API. This is a common issue. You might be able to fix this by rebooting the cameras.
