Invalid encryption key - Multiple Entries, How to Remove?
I have been receiving ‘Invalid encryption key’ errors in esphome and I believe it is because I have multiple devices listed in esphome pointing at the same device but under different names. I have one called “Esp32-BME680-LD2410” and one called “Test-ESP” however when I open them both up to see the related entities they show the same entities under each. I assume this occurred when I was trying to add and delete some original setup. I am hoping that if I can remove one of them it will eliminate the ‘Invalid encryption key’ errors. I am not sure how to go about deleting the device or what impact it might have on the other device.
What would be the proper way to remove the extra duplicate device without impact to the other and would this hopefully remove the ‘Invalid encryption key’ error I am getting?
