Invalid GPT, no ethernet
Hi Guys,
I’m trying to install Hass.io on my new Raspberry Pi 3 b+. For that I downloaded 32 bit image and put it on 16 GB Kingston SD card. Unfortunately Raspberry doesn’t boot. It throws errors like on the screenshot:
It looks like it doesn’t even enable ethernet interface and later failing during boot from sd card. I tried to format sd card on different ways, on MacOS or Windows.
Lan cable is fine, tested that. Charger is dedicated for Raspberry.
I will go to buy sandisk 32GB card to see if its helps. But I doubt that the card could be the reason.
Anyone has similar problem?
I seem to be having the same issue with the Kingston 32 gb version
Sandisk SD card resolved the problem… So only thing which I can advise you is to buy it.
