So I have been running HA for a while now. Since I’m in an apartment building where I cannot forward ports, I’m running a reverse proxy.
To do this, I’m using inlets and a separate server from azure with a fixed IP and the ability to forward ports. My configuration is as following
HA on RPi 4 <–(inlet)–> Azure server (running caddy server for reverse proxy) with fixed IP
This all used to work fine, but after updating to the latest version of HA today, I can no longer reach my home assistant via my domain that points to the azure server.
Assume that my domain is called mydomain.com and points to the azure servers IP.
Part of my HA config:
http:
use_x_forwarded_for: true
trusted_proxies:
- YY.YY.YY.YY # address of the azure server
- 127.0.0.1
My inlet-client config (on the Pi)
inlets client --remote=wss://mydomain.com --token=XXXXX
--upstream=mydomain.com=http://localhost:8123
My server inlet config (on the azure server)
inlets server --port=8888 --token=XXXXX
And finally, my Caddyfile on the azure server:
mydomain.com
reverse_proxy /* 127.0.0.1:8888 {
header_up Host {http.request.host}
header_up X-Real-IP {http.request.remote}
header_up X-Forwarded-For {http.request.remote}
# header_up X-Forwarded-Port {http.request.port}
header_up X-Forwarded-Proto {http.request.scheme}
reverse_proxy /tunnel 127.0.0.1:8888 {
The error I’m getting is the following:
Invalid IP address in X-Forwarded-For: XX.XXX.XXX.XX:14883, 127.0.0.1
with XX.XXX.XXX.XX being the ip of whatever device I’m trying to reach HA with.
From the other threads on this issue (Update broke Apache Reverse Proxy - #16 by delzear), it seems that the port being part of the X-Forwarded-For is the issue. As such, I already tried to uncomment those regions in the Caddyfile, yet the issue persists.
Any idea what I could do?
Edit:
Trying to reverse the code alone, it is indeed the port that is giving the issue:
Calling forwarded_for = [ip_address(addr.strip()) for addr in forwarded_for_split]
gives me:
ValueError: 'XX.XXX.XXX.XX:14883' does not appear to be an IPv4 or IPv6 address
