My HAOS z-wave network is becoming non-functional after a few days. Here are some of the stats.
HA core: 2024.11.3
HAOS: 13.2
ZST39 LR Firmware 1.50 USB stick on 1’ USB extender cable
64 devices
Also host a Zigbee stick (also on 1’ USB extender cable)
Host system: Beelink Mini S12 Pro Mini PC, 12th Intel Alder Lake-N100, 16 GB Memory, 500 GB SSD.
I see random disconnects with 800 Z-wave stick in the log over time. Then log indicates jammed sessions and finally non-functional. Once this happens only a cold start will resolve the problem as reboots are ineffective. Contacted Zooz but they sent me to Github. Not sure how to post properly there. Pretty sure I have the latest firmware on the stick. I am told “no one” is having this problem but somehow I don’t believe that. The “invalid payload” messages don’t seem to reference a node, so I assume the driver is reporting that.
While all the RSSI I’ve seen in the debug log indicate everything should be well within range, I relocated the host in the middle of my house with no device more than 60’ away now and undergoing a z-wave network rebuild at this time to see if that has any effect.
(segment of startup log)
Closing server...
Server closed
[10:20:35] INFO: e[32mService restart after closinge[0m
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[05:28:16] INFO: e[32mNo 'network_key' detected, setting it to 's0_legacy_key' for backwards compatibilitye[0m
[05:28:16] INFO: e[32mFlushing config to disk due to creation of new key(s)...e[0m
[05:28:17] INFO: e[32mSoft-reset set to automatice[0m
[05:28:17] INFO: e[32mVirtual Machine not detected, enabling soft-resete[0m
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[05:28:17] INFO: e[32mSuccessfully send discovery information to Home Assistant.e[0m
2024-12-09T10:28:18.151Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2024-12-09T10:28:18.152Z DRIVER version 13.10.3
2024-12-09T10:28:19.174Z CONFIG version 13.10.3
2024-12-09T10:28:19.363Z CNTRLR querying Serial API capabilities...
2024-12-09T10:28:20.436Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2024-12-09T10:28:21.166Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2024-12-09T10:28:21.166Z DRIVER Dropping message because it contains invalid data
2024-12-09T10:28:21.175Z DRIVER Dropping message with invalid payload:
0x012c00a800000100031e9f0328004e63a1b360ab8c0c3887532ce3ba320001e68a3f4f68728a
d90200a8007f7ff2
2024-12-09T10:28:21.183Z DRIVER Dropping message with invalid payload:
0x012c00a800000100051e9f03ac0047f5a1e6e07765055669fe0055de628124d418e3debde5a4
122e00b2007f7f5d
2024-12-09T10:28:21.190Z DRIVER Dropping message with invalid payload:
0x012800a800000100591a9f037000ab13c69d23d398917726413aaf849515362fcb651d7900ad
007f7f34
2024-12-09T10:28:21.197Z DRIVER Dropping message with invalid payload:
0x012800a800000100361a9f0306009bad54a32c9b882d6c30fcabd6115142c606717c559900af
007f7f6a
2024-12-09T10:28:21.204Z DRIVER Dropping message with invalid payload:
0x012800a800000100041a9f031c00252c3e8fb577b33f762138d2105586680a3ad9c36ab200ac
007f7f5e
2024-12-09T10:28:21.212Z DRIVER Dropping message with invalid payload:
0x012800a800000100521a9f03c100ffcf6b12d573380ba4687eabd01b669ca0e2febcacb300aa
007f7f2a
2024-12-09T10:28:21.219Z DRIVER Dropping message with invalid payload:
0x012800a800000100521a9f03c400e2abf7c2c3d5c5d67186b9d3cdce24480519df36eae800aa
007f7fb8
2024-12-09T10:28:21.553Z DRIVER Dropping message with invalid payload:
0x012800a800000100051a9f03b0002243a9c0911869fd22899b3e7978672660d6a3916cf100b2
007f7fbd
2024-12-09T10:28:22.073Z DRIVER Dropping message with invalid payload:
0x012400a8000001004d169f03c10090f030cb64c3b32d9d1c6ded51c775c2ea7400a9007f7fc1
2024-12-09T10:28:22.280Z CNTRLR received API capabilities:
firmware version: 1.50
manufacturer ID: 0x027a
product type: 0x04
product ID: 0x0610
supported functions:
· GetSerialApiInitData (0x02)
· SetApplicationNodeInformation (0x03)
· GetControllerCapabilities (0x05)
· SetSerialApiTimeouts (0x06)
· GetSerialApiCapabilities (0x07)
· SoftReset (0x08)
· GetProtocolVersion (0x09)
· SerialAPIStarted (0x0a)
· SerialAPISetup (0x0b)
· SetRFReceiveMode (0x10)
· SendNodeInformation (0x12)
· SendData (0x13)
· SendDataMulticast (0x14)
· GetControllerVersion (0x15)
· SendDataAbort (0x16)
· FUNC_ID_ZW_GET_RANDOM (0x1c)
· GetControllerId (0x20)
· UNKNOWN_FUNC_MEMORY_GET_BYTE (0x21)
· UNKNOWN_FUNC_MEMORY_PUT_BYTE (0x22)
· UNKNOWN_FUNC_MEMORY_GET_BUFFER (0x23)
· UNKNOWN_FUNC_MEMORY_PUT_BUFFER (0x24)
· EnterBootloader (0x27)
· UNKNOWN_FUNC_UNKNOWN_0x28 (0x28)
· GetNVMId (0x29)
· ExtNVMReadLongBuffer (0x2a)
· ExtNVMReadLongByte (0x2c)
· NVMOperations (0x2e)
· ClearTxTimers (0x37)
· GetTxTimers (0x38)
· ClearNetworkStats (0x39)
· GetNetworkStats (0x3a)
· GetBackgroundRSSI (0x3b)
· SetListenBeforeTalkThreshold (0x3c)
· ExtendedNVMOperations (0x3d)
· RemoveSpecificNodeIdFromNetwork (0x3f)
· GetNodeProtocolInfo (0x41)
· HardReset (0x42)
· FUNC_ID_ZW_REPLICATION_COMMAND_COMPLETE (0x44)
· FUNC_ID_ZW_REPLICATION_SEND_DATA (0x45)
· AssignReturnRoute (0x46)
· DeleteReturnRoute (0x47)
· RequestNodeNeighborUpdate (0x48)
· ApplicationUpdateRequest (0x49)
· AddNodeToNetwork (0x4a)
· RemoveNodeFromNetwork (0x4b)
· AddPrimaryController (0x4d)
· AssignPriorityReturnRoute (0x4f)
· SetLearnMode (0x50)
· AssignSUCReturnRoute (0x51)
· RequestNetworkUpdate (0x53)
· SetSUCNodeId (0x54)
· DeleteSUCReturnRoute (0x55)
· GetSUCNodeId (0x56)
· SendSUCNodeId (0x57)
· AssignPrioritySUCReturnRoute (0x58)
· ExploreRequestInclusion (0x5e)
· ExploreRequestExclusion (0x5f)
· RequestNodeInfo (0x60)
· RemoveFailedNode (0x61)
· IsFailedNode (0x62)
· ReplaceFailedNode (0x63)
· undefined (0x65)
· RequestProtocolCCEncryption (0x68)
· GetRoutingInfo (0x80)
· LockUnlockLastRoute (0x90)
· GetPriorityRoute (0x92)
· SetPriorityRoute (0x93)
· UNKNOWN_FUNC_UNKNOWN_0x98 (0x98)
· VirtualNodeSetNodeInfo (0xa0)
· VirtualNodeSendNodeInfo (0xa2)
· VirtualNodeSetLearnMode (0xa4)
· GetVirtualNodes (0xa5)
· IsVirtualNode (0xa6)
· BridgeApplicationCommand (0xa8)
· SendDataBridge (0xa9)
· SendDataMulticastBridge (0xab)
· GetLibrary (0xbd)
· SendTestFrame (0xbe)
· GetProtocolStatus (0xbf)
· StartWatchdog (0xd2)
· StopWatchdog (0xd3)
· SetMaximumRoutingAttempts (0xd4)
· SetMaxSmartStartInclusionRequestInterval (0xd6)
· undefined (0xd7)
· undefined (0xd8)
· Shutdown (0xd9)
· GetLongRangeNodes (0xda)
· GetLongRangeChannel (0xdb)
· SetLongRangeChannel (0xdc)
· SetLongRangeShadowNodeIDs (0xdd)
· Proprietary_DE (0xde)
· Proprietary_DF (0xdf)
· Proprietary_E7 (0xe7)
· Proprietary_E8 (0xe8)
2024-12-09T10:28:22.281Z CNTRLR querying additional controller information...
2024-12-09T10:28:22.291Z CNTRLR received additional controller information:
Z-Wave API version: 1 (official)
Z-Wave chip type: EFR32ZG23 / ZGM230S
node type Controller
controller role: primary
controller is the SIS: true
controller supports timers: false
Z-Wave Classic nodes: 1, 3, 4, 5, 9, 12, 13, 14, 15, 16, 17, 19, 20, 2
1, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 41, 43, 44, 45,
46, 47, 48, 49, 52, 53, 54, 56, 57, 58, 60, 61, 64, 65, 66, 67, 68, 72, 74, 7
5, 76, 77, 78, 79, 80, 82, 85, 86, 89, 94, 95
2024-12-09T10:28:22.291Z CNTRLR querying version info...
2024-12-09T10:28:22.298Z CNTRLR received version info:
controller type: Bridge Controller
library version: Z-Wave 7.22
2024-12-09T10:28:22.298Z CNTRLR querying protocol version info...
2024-12-09T10:28:22.305Z CNTRLR received protocol version info:
protocol type: Z-Wave
protocol version: 7.22.1
appl. framework build no.: 43981
git commit hash: 63636639623665613165616566313162
2024-12-09T10:28:22.305Z CNTRLR querying controller capabilities...
2024-12-09T10:28:22.310Z CNTRLR received controller capabilities:
controller role: Primary
is the SUC: true
started this network: true
SIS is present: true
was real primary: true
2024-12-09T10:28:22.310Z CNTRLR querying serial API setup capabilities...
2024-12-09T10:28:22.317Z CNTRLR supported serial API setup commands:
· GetSupportedCommands
· SetTxStatusReport
· SetLongRangeMaximumTxPower
· SetPowerlevel
· GetLongRangeMaximumTxPower
· GetPowerlevel
· GetMaximumPayloadSize
· GetLongRangeMaximumPayloadSize
· SetPowerlevel16Bit
· GetPowerlevel16Bit
· GetRFRegion
· SetRFRegion
· SetNodeIDType
2024-12-09T10:28:22.317Z CNTRLR querying max. payload size...
2024-12-09T10:28:22.322Z CNTRLR maximum payload size: 46 bytes
2024-12-09T10:28:22.322Z CNTRLR supported Z-Wave features:
· SmartStart
2024-12-09T10:28:22.322Z CNTRLR Querying configured RF region...
2024-12-09T10:28:22.327Z CNTRLR The controller is using RF region USA (Long Range)
2024-12-09T10:28:22.327Z CNTRLR Querying configured max. Long Range powerlevel...
2024-12-09T10:28:22.332Z CNTRLR The max. LR powerlevel is 14.0 dBm
2024-12-09T10:28:22.332Z CNTRLR Querying configured Long Range channel information...
2024-12-09T10:28:22.337Z CNTRLR received Z-Wave Long Range channel information:
channel: A
supports auto channel selection: true
2024-12-09T10:28:22.337Z CNTRLR Performing soft reset...
2024-12-09T10:28:22.344Z CNTRLR Waiting for the controller to reconnect...
2024-12-09T10:28:22.515Z CNTRLR reconnected and restarted
2024-12-09T10:28:22.516Z CNTRLR Starting hardware watchdog...
2024-12-09T10:28:22.517Z CNTRLR Switching serial API to 16-bit node IDs...
2024-12-09T10:28:22.518Z CNTRLR querying Z-Wave Long Range capabilities...
2024-12-09T10:28:22.534Z CNTRLR Switching to 16-bit node IDs successful
2024-12-09T10:28:22.558Z CNTRLR received Z-Wave Long Range capabilities:
max. payload size: 148 bytes
nodes:
2024-12-09T10:28:22.559Z CNTRLR Switching serial API to 16-bit node IDs...
2024-12-09T10:28:22.564Z CNTRLR Switching to 16-bit node IDs successful
2024-12-09T10:28:22.564Z CNTRLR querying controller IDs...
2024-12-09T10:28:22.569Z CNTRLR received controller IDs:
home ID: 0xe4c0be0e
own node ID: 1
2024-12-09T10:28:22.570Z CNTRLR Enabling TX status report...
2024-12-09T10:28:22.575Z CNTRLR Enabling TX status report successful...
2024-12-09T10:28:22.575Z CNTRLR finding SUC...
2024-12-09T10:28:22.579Z CNTRLR This is the SUC
2024-12-09T10:28:22.686Z CNTRLR [Node 001] Embedded device config loaded
(segment of Z-wave log)
2024-12-09T11:50:22.981Z DRIVER » [Node 060] [REQ] [SendDataBridge]
│ source node id: 1
│ transmit options: 0x05
│ callback id: 100
└─[Security2CCNonceReport]
sequence number: 151
SOS: true
MOS: false
receiver entropy: 0x41d207b9ac731e1572c712a782e04214
2024-12-09T11:50:22.988Z SERIAL « [ACK] (0x06)
2024-12-09T11:50:22.991Z SERIAL « 0x010401a90152 (6 bytes)
2024-12-09T11:50:22.991Z SERIAL » [ACK] (0x06)
2024-12-09T11:50:22.991Z DRIVER « [RES] [SendDataBridge]
was sent: true
2024-12-09T11:50:23.008Z SERIAL « 0x012400a8000001003c169f03a6007a313dc96dc9f984e9d8c6f0ef1a3d1b29f50 (38 bytes)
0b0007f7fbc
2024-12-09T11:50:23.009Z DRIVER Dropping message with invalid payload
2024-12-09T11:50:23.010Z DRIVER « [Node 060] [REQ] [BridgeApplicationCommand]
│ RSSI: -80 dBm
└─[Security2CCMessageEncapsulation] [INVALID]
error: Duplicate command (sequence number 166)
2024-12-09T11:50:23.010Z SERIAL » [ACK] (0x06)
2024-12-09T11:50:23.054Z SERIAL « 0x011d00a96400000600b37f7f7f7f01010300000000020200007f7f7f7f7fe6 (31 bytes)
2024-12-09T11:50:23.054Z SERIAL » [ACK] (0x06)
2024-12-09T11:50:23.055Z DRIVER « [REQ] [SendDataBridge]
callback id: 100
transmit status: OK, took 60 ms
routing attempts: 2
protocol & route speed: Z-Wave, 40 kbit/s
routing scheme: LWR
ACK RSSI: -77 dBm
ACK channel no.: 1
TX channel no.: 1
