Klagio
(Klagio)
February 10, 2019, 1:55pm
1
Trying but failing, any help?
The below give error
sensors:
terrace_rain_sensor:
value_template: >-
{%- if is_state("binary_sensor.rain_sensor_terrace", "off")
On
{%- else -%}
Off
{%- endif %}
device_class: moisture
friendly_name: Rain sensor terrace
Your indentation is incorrect. And you need to use all lower case for the states. Try:
sensors:
value_template: >
{% if is_state("binary_sensor.rain_sensor_terrace", "off") %}
on
{% else %}
off
{% endif %}
Klagio
(Klagio)
February 10, 2019, 2:23pm
3
Thanks I will try, following other examples I can across the below code which does not give error when checking configuration. What do you think?
Also other issue I see when the origin binary_sensor is Unavailable, also the inverted binary_sensor should give Unavailable not off …
sensors:
entity_id:
- binary_sensor.rain_sensor_terrace
value_template: >-
{%- if is_state("binary_sensor.rain_sensor_terrace", "on") -%}
Dry
{%- else -%}
Wet
{%- endif -%}
Klagio
(Klagio)
February 10, 2019, 2:26pm
4
your configuration does give error, I have to take out device_class, then there is no error
Sorry, my mistake. Try this:
sensors:
value_template: >
{{ is_state("binary_sensor.rain_sensor_terrace", "off") }}
Not sure why it wouldn’t accept the device_class option. Unless you’re using an older version of HA that didn’t implement that yet for template binary sensors, or didn’t accept moisture as an option. When you get an error it’s helpful to share the detailed error message rather than just saying it didn’t work. Often there is useful clues in the error message.
BTW, you can’t set a template binary_sensor to unavailable. You could do that with a template sensor, though.
Klagio
(Klagio)
February 10, 2019, 2:55pm
6
Ops: I was puttig the code under sensor: and not under binary_sensor: all the time … that’s why all the problems.
YOur code works fine, thanks
