Why would you want to change it? You shouldnt need to if an inverted or not inverted gpio controls the fan, then thats your fan control and you shouldnt have other stuff wired to the same gpio, right?
You do know what ‘Inverted’ is for right? So if a GPIO needs to turn something on/off, you can send logic High or Logic Low because some things need one or the other.
To invert it, it tells you right there in the Docs. The other thing I just noticed is, You already have it Inverted…
What are you trying to accomplish by changing the pin to inverted/not inverted in your config? Are you trying to use that as an ON/OFF switch of some kind? It tells you in the Docs how to to turn the Fan/Output On/OFF. You gotta check that stuff out or else you’re gonna be lost here,. Read those Documentations!
Yes I know what inverted means, in this case it needs high level to stay off but responds to pwm in the normal way while its running, which is why i need the ability to invert the direction when it gets turned on/off. I didnt sdesign the thing just trying to work with it
Well without knowing what “the thing” is, without being able to look up a data sheet or having a security clearence to know about any other details then this is as far as i can help you. What I can tell you though is you cant dynamically change the boolean and toggle the invert configuration on/off. Thats a fixed configuration and can only be changed by reflashing the board. There may may be other ways to do what you want or extra circuitry perhaps but, at this point id just be taking blind guesses and wasting mine and your time.
My fault, I forgot it was a fan. You got a brand and model number? Any details?
I guess im just confused why your fan is the only one ive ever seen that wont turn on/off by calling the fan.turn_on/turn_off or by manually setting the output level to 0.
Calling the fan.turn_on/off does exactly what you need. It. When you call fan.turn_off: does the fan keep spinning?
Which one of these services did you try snd what did it do or not do?
When you say “PWM in the normal way”, are you saying “high” is “off”, but 99% duty cycle (i.e. high for 99% of the time, low for 1%) would be almost full speed (which would be very odd)? Or is actually just inverted, so that 99% high, 1% low would be 1% speed, and 100% high is off? In which case, I don’t understand why just inverting the output pin wouldn’t just work.
You dont understand? I explained it to you. You cant change the pin schema without reflashing. These are not dynamic values that can be changed while the program is running.
You are overthinking this and making it more complicated than it is. It goes over all this in the documentation too. Reading that would clear up the confusion you’re having and you wouldnt be wasting your time trying to reinvent the wheel here.
I assume you didnt try the services like i told you? You wouldnt still be asking if you did. I told you, the service fan.turn_off is basically the same thing as inverting the pin back. It either takes the pwm down to 0% or up to 100% depending on how you configured the pin to begin with. It turns the gpio OFF for you and it knows which way to take it because its the opposite of however you set it up, thats it, its that simple, just go try it. Geeze
“Turns the Output with the given ID OFF when executed”
You have to read the documentation. You cant just go around calling “gpio.invert” functions that dont exist. They make these documents really simple for new people to learn but, you have to actually read them.
