I’m trying to create an automation which turns off switch if binary sensor is on and vice versa. Command in title is “state follower”. But, can be changed to be inverted state follower?
this is what i have; i’d like fan to turn off if light gets on and vice versa:
- platform: state
entity_id:
- binary_sensor.light_cellar
condition: []
- service: switch.turn_{{ trigger.to_state.state }}
entity_id: switch.fan_cellar
Things like “trigger.to_not_state” … don’t work…
Sure, i could solve it with if-else. But, i’d like to keep it as simple as possible.
finity
August 30, 2023, 5:37am
2
- service: switch.turn_{{ 'on' if trigger.to_state.state == 'off' else 'off' }}
mekaneck
(Rick Auch)
August 30, 2023, 6:03am
3
Why not just use
- service: switch.turn_{{ trigger.from_state.state }}
You may want to handle unavailable/unknown states though. Perhaps with:
- platform: state
entity_id:
not_from:
- unavailable
- unknown
condition: []
If you really want to use the to_state
I was able to get rid of the if-else, but didn’t succeed with “keep it as simple as possible”
- service: switch.turn_{{ ( ['on','off'] | sort(reverse=( trigger.to_state.state == 'off') ) )[0] }}
mekaneck
(Rick Auch)
August 30, 2023, 6:27am
4
Just realized that this works and isn’t very complicated
- service: switch.turn_{{ ['on','off'][trigger.to_state.state == 'on'] }}
complex1
(Frank)
August 30, 2023, 1:59pm
5
Try this one?
Should work.
- platform: state
entity_id: binary_sensor.light_cellar
to: ["on", "off"]
Wow, many thanks, guys! Sorry, i’ve been away all day, i’ll test these examples tomorrow.
EDIT: all above solutions work. Thanks again!
