Inverter h2-10k-t2 firware update
I’m want to connect two inverterts to one meter but both inverters show communication problem between in the panel also i’m enable to set an adress of communication to the second inveter
This seems more like a general issue with your inverter and not as much with the Home Assistant server.
You might have way better luck on a forum for inverters or even better a forum for the specific vendor of your inverter.
