Found the problem!
Thanks to the inspiration from WhatPlantsCrave here I found the problem not in TLS version but Google Oauth.
here is my working setup for the future. Ofcourse still a work in progress and open for suggestions
(A massive shoutout to smarthomebeginner for their guides. My config is heavily based on their Traefik Oauth guide and I wouldn’t have gotten this far without them)
Running Traefik v2 in docker-compose, on a NUC machine Ubuntu Server 20.04
docker-compose.yml
version: '3.8'
services:
#? NETWORK CONTAINERS # # # # # # # # # # # # # # #
#? Traefik Reverse Proxy
traefik:
container_name: traefik
hostname: traefik
image: traefik
restart: unless-stopped
security_opt:
- no-new-privileges:true
networks:
- t2_proxy
ports:
- target: 80
published: 80
protocol: tcp
mode: host
- target: 443
published: 443
protocol: tcp
mode: host
- target: 8080
published: 8080
protocol: tcp
mode: host
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- /etc/localtime:/etc/localtime:ro
- $DOCKERDIR/traefik/acme/acme.json:/acme.json
- $DOCKERDIR/traefik/shared:/shared
- $DOCKERDIR/traefik/rules:/rules
- $DOCKERDIR/traefik/traefik.log:/traefik.log
- $DOCKERDIR/traefik:/etc/traefik
environment:
- CF_API_EMAIL=$CLOUDFLARE_EMAIL
- CF_API_KEY=$CLOUDFLARE_API_KEY
labels:
- "traefik.enable=true"
#? HTTP-to-HTTPS Redirect
- "traefik.http.routers.http-catchall.entrypoints=http"
- "traefik.http.routers.http-catchall.rule=HostRegexp(`{host:.+}`)"
- "traefik.http.routers.http-catchall.middlewares=redirect-to-https"
- "traefik.http.middlewares.redirect-to-https.redirectscheme.scheme=https"
#? HTTP Routers
- "traefik.http.routers.traefik-rtr.entrypoints=https"
- "traefik.http.routers.traefik-rtr.rule=Host(`traefik.$DOMAINNAME`)"
- "traefik.http.routers.traefik-rtr.tls=true"
- "traefik.http.routers.traefik-rtr.tls.domains[0].main=$DOMAINNAME"
- "traefik.http.routers.traefik-rtr.tls.domains[0].sans=*.$DOMAINNAME"
#? Services - API
- "[email protected]"
#? Middlewares
#? Google OAuth - Proxy layer using Oauth 2.0
oauth:
container_name: oauth
image: thomseddon/traefik-forward-auth:latest
networks:
- t2_proxy
security_opt:
- no-new-privileges
environment:
- CLIENT_ID=$GOOGLE_CLIENT_ID
- CLIENT_SECRET=$GOOGLE_CLIENT_SECRET
- SECRET=$OAUTH_SECRET
- COOKIE_DOMAIN=$DOMAINNAME
- INSECURE_COOKIE=false
- AUTH_HOST=oauth.$DOMAINNAME
- URL_PATH=/_oauth
- WHITELIST=$MY_EMAIL
- LOG_LEVEL=info
- LOG_FORMAT=text
- LIFETIME=2592000 # 30 days
labels:
#? HTTP Routers
- "traefik.http.routers.oauth-rtr.entrypoints.https"
- "traefik.http.routers.oauth-rtr.rule=Host(`oauth.$DOMAINNAME`)"
- "traefik.http.routers.oauth-rtr.tls=true"
#? HTTP Services
- "traefik.http.routers.oauth-rtr.service=oauth-svc"
- "traefik.http.services.oauth-svc.loadbalancer.server.port=$OAUTH_PORT"
#? Middlewares
#? APP CONTAINERS # # # # # # # # # # # # # # #
homeassistant:
container_name: homeassistant
image: homeassistant/home-assistant:latest
restart: always
security_opt:
- no-new-privileges
privileged: true
network_mode: host
ports:
- target: 8123
published: $HOMEASSISTANT_PORT
protocol: tcp
mode: host
#devices:
# - /dev/ttyUSB0:/dev/ttyUSB0
# - /dev/ttyACM0:/dev/ttyACM0
volumes:
- $DOCKERDIR/homeassistant:/config
- /var/run/docker.sock:/var/run/docker.sock # For Docker Monitor https://github.com/Sanderhuisman/docker_monitor
environment:
- TZ=$TZ
traefik.yml (dynamic conf under $DOCKERDIR/traefik/traefik.yml)
entryPoints:
traefik:
address: ":8080"
http:
address: ":80"
https:
address: ":443"
forwardedHeaders:
trustedIPs:
#* Allow these IPs to set the X-Forwarded-* headers - Cloudflare IPs: https://www.cloudflare.com/ips/
- 173.245.48.0/20
- 103.21.244.0/22
- 103.22.200.0/22
- 103.31.4.0/22
- 141.101.64.0/18
- 108.162.192.0/18
- 190.93.240.0/20
- 188.114.96.0/20
- 197.234.240.0/22
- 198.41.128.0/17
- 162.158.0.0/15
- 104.16.0.0/12
- 172.64.0.0/13
- 131.0.72.0/22
#tls:
#options:
#default:
#minVersion: VersionTLS12
#mintls13:
#minVersion: VersionTLS13
certificatesResolvers:
dns-cloudflare:
acme:
email: $CLOUDFLARE_EMAIL
storage: /acme.json
dnsChallenge:
provider: cloudflare
resolvers:
- "1.1.1.1:53"
- "1.0.0.1:53"
log:
level: ERROR # (Default: error) DEBUG, INFO, WARN, ERROR, FATAL, PANIC
accessLog:
filePath: /traefik.log
bufferingSize: 100 # A buffer of 100 lines
filters:
statusCodes:
- "400-499"
api:
dashboard: true
ping: {}
finally the middlewares.yml and middleware-chain.yml under $DOCKERDIR/traefik/rules
http:
middlewares:
#? Basic Auth which uses a static login from .htpasswd file
middlewares-basic-auth:
basicAuth:
realm: "Traefik2 Basic Auth"
usersFile: "/shared/.htpasswd"
#? Denies request floods (DDoS and CredScan)
middlewares-rate-limit:
rateLimit:
average: 100
burst: 50
#? Security headers for. Headers are the "shipping box" around the website that tells the browser how to handle each component
middlewares-secure-headers:
headers:
accessControlAllowMethods:
- GET
- OPTIONS
- PUT
accessControlMaxAge: 100
hostsProxyHeaders:
- X-Forwarded-Host
sslRedirect: true
stsSeconds: 63072000
stsIncludeSubdomains: true
stsPreload: true
forceSTSHeader: true
customFrameOptionsValue: "allow-from https:$DOMAINNAME"
contentTypeNosniff: true
browserXssFilter: true
# sslForceHost: true
# sslHost: "$DOMAINNAME"
referrerPolicy: "same-origin"
# Setting contentSecurityPolicy is more secure but it can break things. Proper auth will reduce the risk.
# the below line also breaks some apps due to 'none' - sonarr, radarr, etc.
# contentSecurityPolicy = "frame-ancestors '*.example.com:*';object-src 'none';script-src 'none';"
featurePolicy: "camera 'none'; geolocation 'none'; microphone 'none'; payment 'none'; usb 'none'; vr 'none';"
customResponseHeaders:
X-Robots-Tag: "none,noarchive,nosnippet,notranslate,noimageindex,"
server: ""
#? Google Oauth authentication.
middlewares-oauth:
forwardAuth:
address: "http://oauth:4181"
trustForwardHeader: true
authResponseHeaders:
- "X-Forwarded-User"
http:
middlewares:
chain-no-auth:
chain:
middlewares:
- "middlewares-rate-limit"
- "middlewares-secure-headers"
chain-basic-auth:
chain:
middlewares:
- "middlewares-basic-auth"
chain-oauth:
chain:
middlewares:
- "middlewares-oauth"
