iOS 17 and Home Assistnt App
Hi not sure if this is a coincidence. I updated my IPhone to Beta 17.1 and now the home assistant app loads but no dashboards or left menu shows ? Anyone else had this issue and if so any idea on a fix or work around?
Thank you
My app on iOS 17 is working normally.
I’m getting issues with iOS 17. The app gets stuck on Loading Data. I’ve restarted HA, rebooted the machine it runs on, rebooted my router, reset the app, updated to the latest HA. Nothing seems to work. I still get the Loading Data hang.
I can get to my HA instance through Safari though, just not using the app. I also noticed that the app reports as being connected and has picked up all the correct data in terms of what version of HA I’m running, ip address etc. So, it’s connected but can’t get past Loading Data. My wife hasn’t updated to iOS 17 and her app is fine.
A re-install of the app has fixed it.
I had the same issue. I had to uninstall the app AND restart my phone. Then reinstalling worked. Also, when reinstalling, I accepted all the privacy prompts, and then went back after I was in to turn off certain things.
