I just installed Scrypted as an add-on. It works great! Unfortunately I’m permanently locked inside it as far as the mobile app is concerned. I’ve tried force-killing, waiting 5 minutes, and restarting the HA app, but when I restart it goes directly to Scrypted and won’t exit. The developer of Scrypted says this particular UI component is a Home Assistant feature and this bug falls here, not with his add-on.
Good workaround idea - I’ll try thatedit: that worked! I also just did some experimentation with Android and it’s not a problem there. Android puts the full HAOS hamburger menu in the upper left, instead of a single-purpose exit button, and that hamburger is still accessible and works fine.
edit: desktop computer, web management console, stop Scrypted, force kill app, wait, reopen, still get Scrypted but now it’s an error modal with only “ok, I see this error” (effectively) as a confirmation button, press that, then you’re back to normal UI and can navigate.
jchh
(my username is my initials (and my first name isn't John))
4
