I just installed the HA app on my iphone, and part of the app is in Chinese (at least the settings section, I’m not sure what the rest is).
My phone is set in French, ios 11.4.1.
Has someone had a similar issue ?
Thank you
Thank you
Post a screenshot?
Are those in ios app or home assistant?
If they are from home assistant UI, it possible is some translation resource merge issue.
Post a screenshot will help us.
I’m in the same case. How can I do ?
Do you have an idea about that ? My iPhone is set with the french as default language.
In more my first question above (about the Chinese language), I don’t understand because when I restart my HA, the device display I not in my house ( the configuration is more tough with the Chinese version ) however I didn’t move from my house ?
Thank you for your help
