iOS app shows only a blank screen
  • Cleared front-end cache
  • Reset the app
  • Restarted Home Assistant
  • Restarted iPhone
    None of these worked, still a blank/white screen. :frowning:
    This is on my LAN, FYI.
iOS version 14.8.1
Home Assistant Core version core-2021.11.4
When this happens to me, I put my iPhone in landscape mode and swipe from left to right. Then the menu appears. Then I can select the view I want to see.
I had to use that trick many time. Recently, the app seems to be more reliable (latest version on IOS 15.1)
Give it a try…
I’m having this issue. What I do is I pull down the screen, and it works. Would like it to be fixed but don’t know how to help diagnose it.
Same here, any ideas ??
Same here.
Same.
iPhone 5S, iOS 12.5.5.
Usually kill the App and start again - sometimes it helps after 2-3 attempts.
Pulling down to refresh fixes it for my on my ipad running 12.5.5
What do you mean by “pulling down”?
Swiping down?
Usually does not help, does it sometimes.
Pull to refresh
As I said, helps me sometimes only…
For those of you experiencing a blank mobile app due to a front end rendering problem, see my workaround here: iPhone app go to blank screen using Nabu Casa · Issue #2259 · home-assistant/iOS · GitHub
