iOS app through client SSL authentication
I’m testing a secure setup for access HA from outside using client SSL authentication (through NGNIX).
After a few changes and test i get it run with safari (from macOS and iOS) but when i’m trying HA App i always get a 403 forbidden message.
How could i use client certification auth with HA app ? I can use it from Safari in iOS (after import the certificate).
Thanks!
I have found this issue:
https://github.com/home-assistant/home-assistant-iOS/issues/27
Would you mind sharing how you were able to enable client certificates for Safari? I have been able to get client certificates to work for Google Chrome, but Safari does not currently support client certificates over WebSockets (from what I have on Apple RDAR). I found one person who got it working with a lua script but I have not been able to make that solution work due to its use of dated bindings to OpenSSL via Lua.
I’ve posted a response about client certificates here. If you have feedback, please provide it there instead of on the forum.
