So I’ve set up the new auth protocol. Legacy API password support is enabled. However, opening the app prompts me with the username and password login screen, and after I log in, it just shows me this blank screen:
Last time I checked on the device there were no updates for my ios app but the version I had was from Sep 2017 I think. I will have to check at home on the ipad.
I see. IIRC the official released version is not compatible with the new auth system, so you have to use the legacy one. Or you give the beta versino of the app (1.5.0) a spin. It is working pretty reliably for me at least and as far as I know they are pretty close to officialy releasing it.
make sure you have the iOS section in your config,
# iOS Setup
ios:
Just like that, nothing else needed. then it should show up in the discovered section. Dont need to have the legacy setup either, well I dont, just click on your instance, then save, then done, and it should work.
hello, did you solve that problem? i have the same issue except on a ipad mini i gen running ios 9. oll other device running a more recent ios are working, it used to work on that ipad but stopped working
