Is there a way to configure HA to be accessible via the iOS app on the local network only ? I am not interested in allowing remote access to the HA. I did a fresh minimal install using latest version (0.103.3) without success. The app finds the instance http://192.168.1.94:9123 (yes different port number), when it tries to connect, It always gives Error: invalid client_id or redirect uri.
The logs contain
2019-12-21 16:47:00 ERROR (MainThread) [homeassistant.components.auth.indieauth] Timeout while looking up redirect_uri https://home-assistant.io/iOS
2019-12-21 16:47:00 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from 192.168.1.129
As I mentioned, I only interested in accessing the HA from within the local network.
Yes the app works local only but you do need to have working outbound connections and your error indicates your HA can’t talk to the oauth proxy at home-assistant.io.
Lookup of the IP was a bit slow, so I added it to /etc/hosts
PING home-assistant.io (104.25.24.31) 56(84) bytes of data.
64 bytes from home-assistant.io (104.25.24.31): icmp_seq=1 ttl=56 time=31.7 ms
64 bytes from home-assistant.io (104.25.24.31): icmp_seq=2 ttl=56 time=31.3 ms
64 bytes from home-assistant.io (104.25.24.31): icmp_seq=3 ttl=56 time=31.1 ms
