Have been in CV-19 isolation without my Mac (horror!) and working on my setup from my iPhone (XR, 14.1).
I’ve noticed all sorts of fiddly little foibles when editing YAML in the File Editor add-on (perhaps more understandable) / graphic UI before. But this has really bought it home, as it’s unusable in places.
Before I start spending my time filing hundreds of little bug reports, is it just me? I assumed they’d just be so obvious to anyone using it that they’d have been fixed by now (been there since I moved to HA months ago).
In particular:
Cutting and pasting just doesn’t work. Sometimes it will do nothing. Sometimes copies bits of formatting.
Number fields in several places won’t let you delete the first digit. You have to go in front of it, type the number, then go to the end and delete it. Doesn’t always work.
There’s often a mismatch between the visible cursor position and where it actually is, so deleting or adding text ends up somewhere random. Particularly on YAML lines that exceed the screen width.
Exiting scripts / scenes / automations without saving doesn’t work without going back to a higher menu item.
There are loads more.
