Hello everyone,
I have the problem that if the iOS Companion App has no connection to Home Assistant, actions that have not been executed are then executed when the iOS Companion App gets a connection again.
Example: I try to switch on the light, but have no connection to Home Assistant. So nothing is executed. That is ok.
Later, when the iOS Companion App gets a connection again, the light is switched on.
Can this behavior be switched off?
Thank you
