delstel
(delstel)
February 23, 2018, 2:49pm
1
I have 2 iPhone6 setup on 0.63.3. One works the other sort of does.
Hass.io installed on a VM running Ubuntu 16.04 and it has worked properly for over 4 months.
Issues:
The first phone I setup:
The Badge tracks properly
No tracking on the map - only see the zones
All device tracking switched on the phone are setup correctly
No zone enter/leave notifications are received
The second phone I setup:
Setup a week later.
On “map” tracking works properly
The phone setup is exactly the same as the 1st phone.
All zone enter/leave notifications are received
Everything working properly from what I understand from the docs
I have reinstalled hass.io - no change.
All yaml files appear to be correct…
Any ideas on where I should start looking???
Thanks!
Bartem
February 24, 2018, 8:02pm
3
In the iOS app under location settings does it show your Home zone with lat long and radius?
delstel
(delstel)
February 24, 2018, 8:04pm
4
Yes - for both iphone instances…
Bartem
February 24, 2018, 8:07pm
5
Probably assuming you tried deleting and reinstalling app? If so my best guess would be deleting iOS.conf and let it recreate then press the update push settings from app on each phone. I have it on 3 devices and two were flakey at first. Also make sure the device ID in the app is different I had two that just said iPhone which caused some issues
delstel
(delstel)
February 24, 2018, 8:10pm
6
Thanks - I’ll give it a try right now!!
did you mean .ios.conf?
Bartem
February 24, 2018, 8:11pm
7
I don’t think mine is hidden but whatever one is in your config dir
Yes that’s the one
delstel
(delstel)
February 24, 2018, 8:18pm
8
Mine was hidden - I removed it and it was rebuilt ( still hidden ).
But still not shown on the Map
Bartem
February 24, 2018, 8:19pm
9
Are you currently in a “home zone”. Somewhere is a setting to hide when in a zone let me look for it
Bartem
February 24, 2018, 8:21pm
11
There is note that says it won’t show in Home zone
delstel
(delstel)
February 24, 2018, 8:23pm
12
Thanks, I’ll get a friend to check!!! Will take a few minutes
Bartem
February 24, 2018, 8:26pm
13
And as far as the enter exit zone notifications mine are spotty at best but I also don’t work far from home so by the time it notices I left work I’m nearly home so I made a group that uses two device trackers together iOS and asuswrt device discovery it seems to get my lights outside lights on by the time I pull up about 90 percent of the time
delstel
(delstel)
February 24, 2018, 8:30pm
14
I used a python3 script to ping the phone and use mqtt to turn on lights, etc, when I got close to the house. Works very good.
delstel
(delstel)
February 24, 2018, 8:36pm
15
She says that its not visible on the map. I reviewed the ios.conf and before and after updating and it was identical.
delstel
(delstel)
February 24, 2018, 8:59pm
16
Do you show a ._ios_devices.yaml or ios_devices.yaml in /config?
delstel
(delstel)
February 26, 2018, 2:44pm
17
Quick Update: HA 0.64.0 fixed the problem…Thanks
