iOS Live Activity: Different timer behavior when using built-in example vs. executing YAML manually
Hi everyone,
I noticed what appears to be a bug in the Home Assistant Companion App for iOS regarding Live Activities.
Steps to reproduce:
  1. Open the Home Assistant Companion App on iOS.
  2. Navigate to Live Activity → Examples → Workout – Count 20 minutes upwards.
  3. Start the example Live Activity.
  4. Copy the YAML code provided by the example.
  5. Execute the exact same YAML manually in Developer Tools → Actions.
Actual behavior:
Although both methods use the same configuration, they produce different Live Activities:
  • Upper Live Activity (started directly from the example): Displays a timer counting upwards along with a progress bar.
  • Lower Live Activity (started using the copied YAML): Starts counting from 20:00 upwards instead of counting upwards from zero. The progress bar is also missing.
The attached screenshot shows both Live Activities running simultaneously.
Expected behavior:
Executing the YAML manually should produce exactly the same Live Activity as starting it directly from the built-in example, including the count-up timer and progress bar.
Question:
Is this a known bug in the iOS Companion App, or does the built-in example apply additional settings that are not included in the generated YAML?
It would be great if both methods behaved consistently, especially since the examples are intended to demonstrate how to configure Live Activities manually.
Thanks!
Robert
