On the IOS HA mobile app, when I go to (Settings—>Companion app—>Location—>Location). I see a geofence that is not centered over my house. As a matter of fact, my house is not even in it. When I walk through the fence, my iPhone’s presence changes correctly, but since my house is outside the fence I have problems. I see no way to set a new geofence center and radius in the app. Both are grayed out so I can’t change the coordinate or radius. What am I missing? Is there something in the app I have overlooked?
Did you define your location in configuration.yaml?
homeassistant:
latitude: !secret home_lat
longitude: !secret home_long
elevation: 0 # 115
unit_system: metric
currency: AUD
country: AU
time_zone: !secret home_time_zone
If so, that is where you need to change it.
No I haven’t, thank you I will try that. I wonder how it got the original coordinates in the 1st place? What ever did it should have a button to rerun it. Thanks again.
Usually you set your home location during onboarding right after installation.
If you do use the YAML config then the Settings → General page will be disabled.
Try using a web browser to go to that menu first.
