IOS not creating a known device or device_tracker
I recently switched IOS devices and am noticing that since making the change the new device is only showing as a known device under the unifi tracking component.
When trying to push location change to HA the event log will show:
"Location failed to update Failed to send current location to server. The error was The operation couldn’t be completed. (Shared.TokenManager.TokenError error 1.)
The device does not show as a gps tracked device in known_devices or as a device_tracker.
EDIT: Only after re-naming the device to match the old device name did it begin to work. This is even after removing the .ios.conf file.
Hi, I’m having the same issue, did you managed to get it fixed? I see you’ve renamed the device, but thats not working for me :frowning:
