iOS notification stop working
today suddelnly iOS notification stop working with this exception:
2018-12-26 23:40:35 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1924102960] Error handling message: {'type': 'call_service', 'domain': 'notify', 'service': 'ios_mauros_iphone', 'service_data': {'title': 'Bucato terminato', 'message': 'La lavatrice ha finito. Ora puoi stendere il bucato'}, 'id': 8}
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 159, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.6/socket.py", line 745, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 343, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 301, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.6/site-packages/urllib3/connection.py", line 168, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6fdf3710>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 398, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6fdf3710>: Failed to establish a new connection: [Errno -3] Try again',))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/decorators.py", line 16, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/websocket_api/commands.py", line 148, in handle_call_service
    connection.context(msg))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1121, in async_call
    self._execute_service(handler, service_call))
  File "/usr/local/lib/python3.6/site-packages/homeassistant/core.py", line 1143, in _execute_service
    await handler.func(service_call)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/notify/__init__.py", line 117, in async_notify_message
    await notify_service.async_send_message(**kwargs)
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/notify/ios.py", line 94, in send_message
    req = requests.post(PUSH_URL, json=data, timeout=10)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 116, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 60, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='ios-push.home-assistant.io', port=443): Max retries exceeded with url: /push (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x6fdf3710>: Failed to establish a new connection: [Errno -3] Try again',))
I didn’t change anything so I am wondering what happened and how to fix the problem.
Do you have any idea?
M.
I got similar logs this morning. Possibly a problem with the push server?
Everything seems ok now.
It looks to be fine also from my side too
I’ve got the same problem, everything was fine until days ago, and I use mosquito MQTT. What do you mean by push server? Because when it happened the last time, just rebooted and got working again, but it can’t work anymore now.
I mean this: Privacy, rate limiting and security | Home Assistant Companion Docs
You have a different problem. this was a temporary outage.
Have you updated puhs settings in the ios app?
What does MQTT have to do with ios notifications?
What I mean by iOS notification is that my home app notification is not working anymore, not the home assistant app. That is the weird stuff.
