My iOS notifications worked fine until a couple of days ago when they stopped arriving to our phones. I run Hass.io 0.64.3 on a RPi3 with the DuckDNS add-on.
I have updated the iOS app and reinstalled without success.
I get the same errors in the log when I trigger an automation that send notifications.
I don’t understand what they mean but maybe someone smarter could figure out whats wrong?
018-03-07 09:21:17 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.ios_lindas_iphone_app: message=<homeassistant.helpers.template.Template object at 0x6fb351d0>, title=<homeassistant.helpers.template.Template object at 0x6fb35dd0>>
File “/usr/lib/python3.6/site-packages/urllib3/connection.py”, line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File “/usr/lib/python3.6/site-packages/urllib3/util/connection.py”, line 60, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/lib/python3.6/socket.py”, line 745, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 601, in urlopen
chunked=chunked)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 346, in _make_request
self._validate_conn(conn)
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 850, in _validate_conn
conn.connect()
File “/usr/lib/python3.6/site-packages/urllib3/connection.py”, line 284, in connect
conn = self._new_conn()
File “/usr/lib/python3.6/site-packages/urllib3/connection.py”, line 150, in _new_conn
self, “Failed to establish a new connection: %s” % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x70074070>: Failed to establish a new connection: [Errno -3] Try again
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 440, in send
timeout=timeout
File “/usr/lib/python3.6/site-packages/urllib3/connectionpool.py”, line 639, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/lib/python3.6/site-packages/urllib3/util/retry.py”, line 388, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘ios-push.home-assistant.io’, port=443): Max retries exceeded with url: /push (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x70074070>: Failed to establish a new connection: [Errno -3] Try again’,))
File “/usr/lib/python3.6/site-packages/homeassistant/core.py”, line 1010, in _event_to_service_call
yield from service_handler.func(service_call)
File “/usr/lib/python3.6/site-packages/homeassistant/components/notify/init.py”, line 137, in async_notify_message
yield from notify_service.async_send_message(**kwargs)
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/notify/ios.py”, line 94, in send_message
req = requests.post(PUSH_URL, json=data, timeout=10)
File “/usr/lib/python3.6/site-packages/requests/api.py”, line 112, in post
return request(‘post’, url, data=data, json=json, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/api.py”, line 58, in request
return session.request(method=method, url=url, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 508, in request
resp = self.send(prep, **send_kwargs)
File “/usr/lib/python3.6/site-packages/requests/sessions.py”, line 618, in send
r = adapter.send(request, **kwargs)
File “/usr/lib/python3.6/site-packages/requests/adapters.py”, line 508, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘ios-push.home-assistant.io’, port=443): Max retries exceeded with url: /push (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x70074070>: Failed to establish a new connection: [Errno -3] Try again’,))
2018-03-07 09:21:17 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall notify.ios_arons_iphone_app: message=<homeassistant.helpers.template.Template object at 0x6fb35550>, title=<homeassistant.helpers.template.Template object at 0x6fb35fd0>>
chunked=chunked)
conn.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x6ffcd890>: Failed to establish a new connection: [Errno -3] Try again
timeout=timeout
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘ios-push.home-assistant.io’, port=443): Max retries exceeded with url: /push (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x6ffcd890>: Failed to establish a new connection: [Errno -3] Try again’,))
future.result()
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘ios-push.home-assistant.io’, port=443): Max retries exceeded with url: /push (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x6ffcd890>: Failed to establish a new connection: [Errno -3] Try again’,))
