Ios shortcuts and input select
Hey guys,
Im trying to create a ios shortcut to fill in a input_select entity. Did anyone tried already? Im struggling with the syntax and need a little bit help.
my entity looks like this:
input_select:
  radio:
    options:
      - bitte auswählen...
      - Play 181.FM Buzz
      - Play 1LIVE
      - Play Antenne Bayern
      - Play Radio BOB!
      - Play WDR5
    initial: bitte auswählen...
    icon: mdi:radio
The entity is working fine from home assistant app!
Now i want to select the entity from ios shortcut with “Play Radio BOB!” and tried:
The shortcut is successfully executed, but nothing happens. Can someone assist?
thanks in advanced!
regards
Alex
Try this:
Hi M1ke,
thanks for your response! This isnt working too :frowning:
Okay I found the solution for myself :slight_smile:
This is the way how it works:
Strange - because when I tested, it worked perfectly. Maybe you did something different…
