iOS Tracking with new app
Well that is smart! Maybe if I add a delay and then check again like ten minutes later I can catch the away the same way!
Do you get an actual notification or does it happen in the background?
I have it setup with a delay as well to make sure I get the not_home. You don’t get a notification it all happens in the background.
I’ve started doing something similar in Node Red to pull the location every 30 seconds BUT its causing the notification limit to be exceeded:
iOS push notification rate limits for None: 151 sent, 150 allowed, 0 errors, resets in 11:06:40
Is there any other way to do this which doesn’t reply on the push notifications? can it not be called via the devicetracker service instead?
