If you want different color depending on values that will be very sensor specific, and out of scope of my simple script. I suggest adding a function by yourself that take care of that. Similar to how I did with sensor type for moisture, you should be able to apply the same principle to text color.
FWIW: I’ve used data URIs with base64 encoded PNGs to show images in scriptable widgets. See eg. data URI scheme - Wikipedia for more information. Basically convert your image to a data URI (there are many free online services to do this), then
let req = new Request('data:image/png;base64,....')
someStack.addImage(req.loadImage())
is it possible to print attributes of sensors? How?
I have a longer text that is stored in an attribute (due to size limits for sensors) and I would like to show that attribute in the widget.
[later edit] - I managed to print a hard-coded attribute. What would be the filter syntax to return the attribute with a name written in the “sensor.homeassistant_widget_text” array?
I assumed I detect attributes by removing all chars after and including the second dot in the string…
The script is run when the widget updates. It is handled by ios. Don’t expect real-time updates but it should update fairly often automatically. Like every minute or so.
