Hi all,
Someone can explain me the difference between the both widgets ?
The first (best design) open HA when i click on item.
The second, don t open HA (like shortcut) what i prefere but the windows size is not enought ans i dont know how extend.
Can i have some help ? Thx
The first widget is the iOS 14+ widget, which can be placed anywhere on any home screen. The second is the pre-14 widget which is limited in placement.
The major difference is that iOS does not allow the newer style widget to be interactable – it must and can only launch the app, which triggers the action to fire.
Ok thx i understand better.
The seconde is fine for me, but can i adjust the size ? If you look you have the same button between the both but the second is to small for the 5e button ![:sweat_smile: :sweat_smile:](https://community.home-assistant.io/images/emoji/twitter/sweat_smile.png?v=10)
Thx
It is limited but you can tap the “>” chevron to expand it.
Thx for your reply, do you know where i need to insert this chevron ?
In configuration.yaml i think
This is the chevron (red circle):
It’s not something you can configure.
A yes i didnt see the chevron to extend the widget ![:sweat_smile: :sweat_smile:](https://community.home-assistant.io/images/emoji/twitter/sweat_smile.png?v=10)
Thx for your help!
