Hello, I use some input_select helper to switch to some different states. That worked fine until I moved to iOS16, in the Home App I could see the different switches named correctly after the name of the states.
In the new Home App under iOS16 I do see the switches, but they are all named to the name of the input_select helper. Also calling the states via Siri does not work anymore.
Add also some input_select entities and have same issue.
any idea on how to fix this?
Anyway, as a workaround, you acn rename the buttons on the homekit app on the ios device, the result is the same
