I’m curious if anyone has figured out a way to get IOT Link for Windows to work with the Mosquitto Broker Addon reliably. IOT Link is able to connect and provide data; but then shortly after produces a socket error and reconnects again. I have another MQTT client (EventGhost) which connects to the MQTT Broker reliably. It seems like this issue is specific to IOT Link and the Home Assistant MQTT Broker Addon.
1593210514: New connection from 192.168.1.2 on port 1883.
1593210514: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210514: Client MQTTClient disconnected.
1593210514: Socket error on client MQTTClient, disconnecting.
1593210518: New connection from 192.168.1.2 on port 1883.
1593210518: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210519: New connection from 192.168.1.2 on port 1883.
1593210519: Client MQTTClient already connected, closing old connection.
1593210519: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210580: Socket error on client MQTTClient, disconnecting.
1593210583: New connection from 192.168.1.2 on port 1883.
1593210583: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210583: Client MQTTClient disconnected.
1593210585: Client MQTTClient disconnected.
1593210589: New connection from 192.168.1.2 on port 1883.
1593210589: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210590: Client MQTTClient disconnected.
1593210590: New connection from 192.168.1.2 on port 1883.
1593210590: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210590: Socket error on client MQTTClient, disconnecting.
1593210594: New connection from 192.168.1.2 on port 1883.
1593210594: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210594: Client MQTTClient disconnected.
1593210655: Socket error on client MQTTClient, disconnecting.
1593210658: New connection from 192.168.1.2 on port 1883.
1593210658: New client connected from 192.168.1.2 as MQTTClient (p2, c1, k60, u'mkanet').
1593210658: Client MQTTClient disconnected.
1593210661: Socket error on client MQTTClient, disconnecting.
